0016043 | ParaView | (No Category) | public | 2016-03-24 21:31 | 2016-08-12 10:00 | ||||
Product Version | 5.0.1 | ||||||||
Target Version | 5.1 | Fixed in Version | |||||||
Summary | 0016043: Multiple dataset, volume rendering, remote server weirdnesses | ||||||||
Description | We have a strange set of attributes to ParaView when running multiple datasets, one volume rendered, remote server. Here is how to replicate: * Master, Linux, 8 remote servers. (May not show with fewer - I don't know.) (Does not show up Local server.) * Load disk_out_ref.exo. All vars on. Apply. * Color by Temp. Volume render. * Load can.exo. All vars on. Apply. <<Bug>> Rotate the can around. You will find a big red stripe on the top of the can.exo's plate. * Turn visibility off for disk_out_ref.exo. <<Bug>> The can is now being clipped in a crazy way. Only the upper left quadrant shows, and as you move it around, these clip planes change. Marking for 5.1, since this one could be super confusing. This is a good example of how to fix it. | ||||||||
Project | Sandia | ||||||||
(0039020) Kitware Robot (administrator) 2016-08-12 10:00 |
2016-03-24 21:31 | Alan Scott | New Issue | |
2016-03-24 21:31 | Alan Scott | Target Version | => 5.1 |
2016-08-12 10:00 | Kitware Robot | Note Added: 0039020 | |
2016-08-12 10:00 | Kitware Robot | Status | backlog => closed |
2016-08-12 10:00 | Kitware Robot | Resolution | open => moved |
2016-08-12 10:00 | Kitware Robot | Assigned To | => Kitware Robot |
