0016046 | ParaView | (No Category) | public | 2016-03-25 19:27 | 2016-08-12 10:00 | ||||
Product Version | 5.0.1 | ||||||||
Summary | 0016046: Hide cells and blocks shortcut | ||||||||
Description | Here is a request from a user. What I envision is an additional button like the "Interactive Select Cells On". Something like "Interactive Hide Cells On" and Interactive Hide Blocks On". OK, verbiage from my user: This is a feature or enhancement request for helping to speed up post-processing of a typical system-level analysis that we do. It can take a long time to "drill down" to visualize the element (cell) block that we are interested in. For example, we may have a large system model with hundreds of blocks, but all we really care about is a spring or screw that's buried inside some wall and hidden from view by cement, epoxies, plywood or other parts. It would be nice to have a single 'hot-key' to hide a series of blocks by picking. Yes, there are other ways of doing this (load only the blocks of interest, cutting planes, etc.), but sometimes this isn't known a-priori and it'd be nice to be able to click-navigate through a model more easily. Anyways, I envision something like: *User presses "H" key to toggle 'block hiding mode', cursor turns into a 'target' *User clicks on a block, that block is hidden. *User clicks on another block, that block is hidden. *User clicks on another block, that block is hidden. *User presses "H" key to toggle 'block hiding mode' off, cursor returns to normal. | ||||||||
Project | Sandia | ||||||||
Type | feature | ||||||||
(0039022) Kitware Robot (administrator) 2016-08-12 10:00 |
2016-03-25 19:27 | Alan Scott | New Issue | |
2016-08-12 10:00 | Kitware Robot | Note Added: 0039022 | |
2016-08-12 10:00 | Kitware Robot | Status | backlog => closed |
2016-08-12 10:00 | Kitware Robot | Resolution | open => moved |
2016-08-12 10:00 | Kitware Robot | Assigned To | => Kitware Robot |
