0016079 | ParaView | (No Category) | public | 2016-04-19 11:07 | 2016-08-12 10:00 | ||||
Assigned To | T.J. Corona | ||||||||
Product Version | 5.0 | ||||||||
Target Version | 5.1 | Fixed in Version | |||||||
Summary | 0016079: Possible negative magnitude when coloring by vectors with angular periodic filter | ||||||||
Description | The range on the color bar sometimes gives strange results when using the Angular Periodic Filter. In particular it is possible to get negative values for a vector magnitude. To replicate, do the following. 1. Create a plane source. Origin = [0,0,0], Point1 = [1,0,0], Point2 = [0,1,0]. Apply. 2. Add the calculator filter. Make the expression "coords" (just the point coordinates). Apply. 3. Add Angular Periodic Filter. Rotation Angle = 90. Axis = Z. Apply. 4. Color by "Result" and "Magnitude" Note that the range of the magnitude starts at -1, which is clearly wrong. | ||||||||
Project | Sandia | ||||||||
(0036088) T.J. Corona (developer) 2016-06-21 08:22 |
This issue is addressed in commit ea6cfe57d5c50c899dde59653e686aa0956351c8 |
(0039035) Kitware Robot (administrator) 2016-08-12 10:00 |
2016-04-19 11:07 | Ken Moreland | New Issue | |
2016-04-19 13:24 | Alan Scott | Project | TBD => Sandia |
2016-04-19 13:24 | Alan Scott | Target Version | => 5.1 |
2016-06-21 08:17 | T.J. Corona | Assigned To | => T.J. Corona |
2016-06-21 08:22 | T.J. Corona | Note Added: 0036088 | |
2016-06-21 08:22 | T.J. Corona | Status | backlog => gatekeeper review |
2016-06-21 08:22 | T.J. Corona | Resolution | open => fixed |
2016-08-12 10:00 | Kitware Robot | Note Added: 0039035 | |
2016-08-12 10:00 | Kitware Robot | Status | gatekeeper review => closed |
2016-08-12 10:00 | Kitware Robot | Resolution | fixed => moved |
