0016106 | ParaView | (No Category) | public | 2016-04-29 15:11 | 2016-08-12 10:00 | ||||
Reporter | Cory Quammen | ||||||||
Assigned To | Cory Quammen | ||||||||
Product Version | 5.0.1 | ||||||||
Summary | 0016106: Auto convert may cause failure to reset Threshold's range values | ||||||||
Description | For some variables, having the Auto Convert Properties enabled in the settings will cause the Threshold filter's "Reset using current data values" to not update correctly. | ||||||||
Project | Sandia | ||||||||
(0036108) Cory Quammen (developer) 2016-06-27 04:11 |
Could not reproduce. Here's what I tried: - ParaView, local server - make sure auto apply is on - Add Sphere Source - Add Generate Ids filter - Add Calculator filter, Cell Data, expression set to 1*Ids - Add Threshold filter, threshold on Cell Data Result variable - Go back and change Calculator filter expression to 2*Ids - In Threshold filter, click the threshold range reset button. It appears to be updated just fine. |
(0036109) Cory Quammen (developer) 2016-06-27 04:14 |
It looks like this bug got fixed along the way. |
(0039049) Kitware Robot (administrator) 2016-08-12 10:00 |
2016-04-29 15:11 | Cory Quammen | New Issue | |
2016-06-27 04:11 | Cory Quammen | Note Added: 0036108 | |
2016-06-27 04:14 | Cory Quammen | Note Added: 0036109 | |
2016-06-27 04:14 | Cory Quammen | Status | backlog => gatekeeper review |
2016-06-27 04:14 | Cory Quammen | Resolution | open => fixed |
2016-06-27 04:14 | Cory Quammen | Assigned To | => Cory Quammen |
2016-08-12 10:00 | Kitware Robot | Note Added: 0039049 | |
2016-08-12 10:00 | Kitware Robot | Status | gatekeeper review => closed |
2016-08-12 10:00 | Kitware Robot | Resolution | fixed => moved |
