0016750 | ParaView | (No Category) | public | 2016-06-17 19:37 | 2016-08-12 10:00 | ||||
Product Version | 5.1 | ||||||||
Summary | 0016750: volume() doesn't work for CTH AMR data | ||||||||
Description | Please fix the python volume() function for CTH flat mesh and AMR mesh datasets. Needs to work in parallel. Here is how to replicate: Remote server, Linux, master. * Load Dave's small CTH AMR dataset. All vars on, apply. * Python Calculator. Expression: volume(inputs[0]). Array Association: Cell Data. Apply. * Now paint by result. It is -1, which is an error condition. This needs to be fixed. | ||||||||
Project | Sandia | ||||||||
(0036081) Alan Scott (manager) 2016-06-17 19:41 |
I wanted to mention that dave's small amr dataset is 8X4X4 == 128 units. From there, using the integrate variable filter, it should be easy to figure out if this bug has been fixed. |
(0039072) Kitware Robot (administrator) 2016-08-12 10:00 |
2016-06-17 19:37 | Alan Scott | New Issue | |
2016-06-17 19:41 | Alan Scott | Note Added: 0036081 | |
2016-08-12 10:00 | Kitware Robot | Note Added: 0039072 | |
2016-08-12 10:00 | Kitware Robot | Status | backlog => closed |
2016-08-12 10:00 | Kitware Robot | Resolution | open => moved |
2016-08-12 10:00 | Kitware Robot | Assigned To | => Kitware Robot |
