0016763ParaView(No Category)public2016-06-29 15:132016-08-12 10:00
ReporterAlan Scott
Assigned ToKitware Robot
StatusclosedResolutionmoved
PlatformOSOS Version
Product Version5.0.1
Summary0016763: Modifications to plot selection over time
DescriptionThe PlotSelectionOverTime filter needs to be cleaned up, both for single and multiple point selections.
Here is my usecase:
* local server, Linux, 5.0.1.
* Open can.exo, all vars on, Apply.
* Select 2 to 4 points.
* PlotSelectionOverTime. Apply.
Here is what is needed:
* Only Report Selection Statistics section.
** Delete the "Only Report Selection Statistics.
** Add a combo box at the top of the Properties section. Three options - 1) "Report Statistics For Larger Selections", 2) "Plot Each Selection As Its Own Line" and 3) "Only Report Selection Statistics". Default will be 1).
** Make option 1) draw lines for 4 or fewer points or cells selected, statistics for more. Make this user select-able and sticky.
* Selecting Only Report Selection Statistics, un-select X, Y and Z by default.
* Unselecting Only Report Selection Statistics, in the Composite Data Set Index, turn on all points by default. Users selected them, they want them. You could even get rid of this section, for all I care.
* Unselecting Only Report Selection Statistics, in the Series Parameters, don't split each point or cell out. If a user selects a few hundred items, don't make them check each one. For instance, have only one DISPL_Magnitude.
* Unselecting Only Report Selection Statistics, I believe we are reporting ID. This is an internal to ParaView index - if available, we should be using globalNodeId or globalElementId.
TagsNo tags attached.
ProjectSandia
Topic Name
Typeincorrect functionality
 Relationships
  Notes
(0039080)
Kitware Robot (administrator)
2016-08-12 10:00
Resolving issue as `moved`.
 Issue History
2016-06-29 15:13 Alan Scott New Issue
2016-06-29 15:13 Alan Scott Assigned To => Alan Scott
2016-06-29 21:00 Alan Scott Assigned To Alan Scott =>
2016-08-12 10:00 Kitware Robot Note Added: 0039080
2016-08-12 10:00 Kitware Robot Status backlog => closed
2016-08-12 10:00 Kitware Robot Resolution open => moved
2016-08-12 10:00 Kitware Robot Assigned To => Kitware Robot
