0016767 | ParaView | (No Category) | public | 2016-07-01 11:15 | 2016-08-12 10:00 | ||||
Reporter | Mathieu Westphal | ||||||||
Assigned To | Mathieu Westphal | ||||||||
Summary | 0016767: RenderView management with python segfault | ||||||||
Description | There is a systematic segfault with the following code in pvpython : Basically, Creating and rendering a first view, then Creating and rendering a second render view, then destroying the first view, will put the second in a unstable state that will lead to a segfault. Does not reproduce in paraview. | ||||||||
Steps To Reproduce | from paraview.simple import * import gc v=CreateRenderView() Render(v) w=CreateRenderView() Render(w) Delete(v) del v gc.collect() # not absolutally necessary, the destructor will be called eventually Render(w) [xcb] Unknown sequence number while appending request [xcb] Most likely this is a multi-threaded client and XInitThreads has not been called [xcb] Aborting, sorry about that. pvpython: xcb_io.c:161: append_pending_request: Assertion `!xcb_xlib_unknown_seq_number' failed. Aborted (core dumped) | ||||||||
Project | TBD | ||||||||
Attached Files | ![]() | ||||||||
(0039083) Kitware Robot (administrator) 2016-08-12 10:00 |
2016-07-01 11:15 | Mathieu Westphal | New Issue | |
2016-07-01 11:15 | Mathieu Westphal | Assigned To | => Mathieu Westphal |
2016-07-01 11:15 | Mathieu Westphal | Description Updated | |
2016-07-01 11:15 | Mathieu Westphal | Steps to Reproduce Updated | |
2016-07-01 11:17 | Mathieu Westphal | File Added: bugRender.py | |
2016-08-12 10:00 | Kitware Robot | Note Added: 0039083 | |
2016-08-12 10:00 | Kitware Robot | Status | backlog => closed |
2016-08-12 10:00 | Kitware Robot | Resolution | open => moved |
