0016784 | ParaView | (No Category) | public | 2016-07-13 15:32 | 2016-07-14 11:34 | ||||
Reporter | Shawn Waldon | ||||||||
Target Version | Fixed in Version | git-master | |||||||
Summary | 0016784: PlotMatrixView array order has changed | ||||||||
Description | The test pv.PlotMatrixViewArraySelection has found a difference between the OpenGL and OpenGL2 backends in the PlotMatrixView. The order that the data arrays are positioned in has changed. See the attached files for an example of what this looks like before and after. For now we are adding a new baseline so that the builds are green... | ||||||||
Project | TBD | ||||||||
Attached Files | PlotMatrixViewArraySelection.png [^] (20,681 bytes) 2016-07-13 15:32
PlotMatrixViewArraySelection.opengl2.png [^] (16,384 bytes) 2016-07-13 15:33 | ||||||||
(0036408) Utkarsh Ayachit (administrator) 2016-07-13 15:36 |
BTW, this bug is just to figure out what's happening and then decide if the new order in OpenGL2 is indeed correct. |
(0036470) Utkarsh Ayachit (administrator) 2016-07-14 11:34 |
Not a bug. See notes here here:https://gitlab.kitware.com/paraview/paraview/merge_requests/884#note_138937 [^] |
2016-07-13 15:32 | Shawn Waldon | New Issue | |
2016-07-13 15:32 | Shawn Waldon | Assigned To | => Mathieu Westphal |
2016-07-13 15:32 | Shawn Waldon | File Added: PlotMatrixViewArraySelection.png | |
2016-07-13 15:33 | Shawn Waldon | File Added: PlotMatrixViewArraySelection.opengl2.png | |
2016-07-13 15:36 | Utkarsh Ayachit | Note Added: 0036408 | |
2016-07-14 11:34 | Utkarsh Ayachit | Note Added: 0036470 | |
2016-07-14 11:34 | Utkarsh Ayachit | Status | backlog => closed |
2016-07-14 11:34 | Utkarsh Ayachit | Assigned To | Mathieu Westphal => Utkarsh Ayachit |
2016-07-14 11:34 | Utkarsh Ayachit | Resolution | open => no change required |
2016-07-14 11:34 | Utkarsh Ayachit | Fixed in Version | => git-master |
