0016786 | ParaView | (No Category) | public | 2016-07-13 19:49 | 2016-08-12 10:00 | ||||
Assigned To | Nathan Fabian | ||||||||
Summary | 0016786: Crash saving 2d glyph as exodus dataset | ||||||||
Description | There is a crash when saving a 2d glyph as an exodus dataset. * Linux, 5.1.1, local server. * Sources/ 2d Glyph. Apply. * File/ Save Data/ Exodus/ take defaults/ OK. Crash. Following is the output: Qt has caught an exception thrown from an event handler. Throwing exceptions from an event handler is not supported in Qt. You must reimplement QApplication::notify() and catch all exceptions there. terminate called after throwing an instance of 'std::logic_error' what(): basic_string::_S_construct NULL not valid Abort (core dumped) | ||||||||
Project | Sandia | ||||||||
Type | crash | ||||||||
Relationships | ||||||
(0036525) Nathan Fabian (developer) 2016-07-18 14:02 |
This has been fixed in the following MR: https://gitlab.kitware.com/vtk/vtk/merge_requests/1717 [^] |
(0036610) Utkarsh Ayachit (administrator) 2016-07-26 16:43 |
This is now merged in master (v5.1.0-175-g16ef22a) |
(0039095) Kitware Robot (administrator) 2016-08-12 10:00 |
2016-07-13 19:49 | Alan Scott | New Issue | |
2016-07-13 19:49 | Alan Scott | Assigned To | => Alan Scott |
2016-07-13 19:50 | Alan Scott | Relationship added | related to 0010026 |
2016-07-14 14:39 | Alan Scott | Assigned To | Alan Scott => |
2016-07-18 14:02 | Nathan Fabian | Note Added: 0036525 | |
2016-07-18 14:02 | Nathan Fabian | Assigned To | => Utkarsh Ayachit |
2016-07-18 14:02 | Nathan Fabian | Status | backlog => todo |
2016-07-26 16:43 | Utkarsh Ayachit | Note Added: 0036610 | |
2016-07-26 16:43 | Utkarsh Ayachit | Status | todo => customer review |
2016-07-26 16:43 | Utkarsh Ayachit | Fixed in Version | => git-master |
2016-07-26 16:43 | Utkarsh Ayachit | Resolution | open => fixed |
2016-07-26 16:43 | Utkarsh Ayachit | Assigned To | Utkarsh Ayachit => Nathan Fabian |
2016-08-12 10:00 | Kitware Robot | Note Added: 0039095 | |
2016-08-12 10:00 | Kitware Robot | Status | customer review => closed |
2016-08-12 10:00 | Kitware Robot | Fixed in Version | git-master => |
2016-08-12 10:00 | Kitware Robot | Resolution | fixed => moved |
