0016800 | ParaView | (No Category) | public | 2016-07-28 14:56 | 2016-08-12 10:00 | ||||
Product Version | 5.1 | ||||||||
Summary | 0016800: Color palettes and undo/redo causes crash | ||||||||
Description | Color palettes are not behaving correctly with the undo/redo feature. It is causing lots of bizarre behavior including crashes. To replicate, do the following: 1. Create a Cylinder source. Apply. 2. Hit undo until you reach the end of the stack. 3. Hit redo until you reach the end of the stack. 4. Change the color palette to Black Background When you change the color palette to Black Background, ParaView crashes. (I can replicate this on Windows and Mac.) There is other weird behavior that is probably related. For example, if you follow steps 1-3 and then go to settings, the Color Palette tab is missing. | ||||||||
Project | TBD | ||||||||
Type | crash | ||||||||
(0039106) Kitware Robot (administrator) 2016-08-12 10:00 |
2016-07-28 14:56 | Ken Moreland | New Issue | |
2016-07-28 14:57 | Ken Moreland | Priority | normal => high |
2016-08-12 10:00 | Kitware Robot | Note Added: 0039106 | |
2016-08-12 10:00 | Kitware Robot | Status | backlog => closed |
2016-08-12 10:00 | Kitware Robot | Resolution | open => moved |
2016-08-12 10:00 | Kitware Robot | Assigned To | => Kitware Robot |
