0001940 | ParaView | (No Category) | public | 2005-06-15 17:10 | 2009-12-09 14:50 | ||||
Reporter | Dan Goldstein | ||||||||
Summary | 0001940: Run time error | ||||||||
Description | Run time error reading in a session file: "The instruction at "0x77532aa4" referenced memory at "0x0f442720". The memory could nto be "read"." Looking at the trace file I see that the errors start when it can't find a data file (mine). It would be better to exit more gracefully. As always thanks for the great work.. trace file: set kw(vtkTemp5) [$Application GetMainWindow] set kw(vtkTemp23) [$kw(vtkTemp5) GetMainView] set kw(vtkTemp661) [$kw(vtkTemp5) InitializeReadCustom "legacyreader" "C:/dan/research/wavelet_code/results.local/results/vortex_array_1..0001_vorticity.vtk"] $kw(vtkTemp5) ReadFileInformation $kw(vtkTemp661) "C:/dan/research/wavelet_code/results.local/results/vortex_array_1..0001_vorticity.vtk" $kw(vtkTemp5) FinalizeRead $kw(vtkTemp661) "C:/dan/research/wavelet_code/results.local/results/vortex_array_1..0001_vorticity.vtk" set kw(vtkTemp662) [$kw(vtkTemp661) GetPVWidget {Filename}] $kw(vtkTemp662) SetValue "C:/dan/research/wavelet_code/results.local/results/vortex_array_1..0001_vorticity.vtk" $kw(vtkTemp5) SetCenterOfRotation -0.098175 -0.098175 -0.098175 $kw(vtkTemp5) SetCenterOfRotation -0.098175 -0.098175 -0.098175 set kw(vtkTemp670) [$kw(vtkTemp5) GetPVColorMap {vorticity} 3] $kw(vtkTemp670) SetScalarBarTitle {vorticity} set kw(vtkTemp751) [$kw(vtkTemp5) CreatePVSource DataSetTriangleFilter] set kw(vtkTemp756) [$kw(vtkTemp751) GetPVWidget {Input}] $kw(vtkTemp756) SetCurrentValue $kw(vtkTemp661) $kw(vtkTemp751) AcceptCallback $kw(vtkTemp23) SetCameraState -6.459 10.158 16.309 -0.098 -0.098 -0.098 0.344 0.850 -0.398 set kw(vtkTemp39) [$kw(vtkTemp751) GetPVOutput] $kw(vtkTemp39) DrawWireframe $kw(vtkTemp23) SetCameraState -6.446 11.926 15.065 -0.098 -0.098 -0.098 0.375 0.796 -0.474 $kw(vtkTemp39) DrawPoints $kw(vtkTemp39) DrawVolume $kw(vtkTemp39) VolumeRenderPointField {vorticity} 3 $kw(vtkTemp23) SetCameraState 10.813 17.087 0.555 -0.098 -0.098 -0.098 -0.222 0.104 0.970 $kw(vtkTemp23) SetCameraState 13.364 13.501 6.875 -0.098 -0.098 -0.098 -0.403 -0.069 0.912 $kw(vtkTemp23) SetCameraState 10.018 5.866 16.543 -0.098 -0.098 -0.098 -0.779 -0.264 0.568 $kw(vtkTemp23) SetCameraState -6.577 -12.045 15.071 -0.098 -0.098 -0.098 -0.894 -0.076 -0.442 $kw(vtkTemp23) SetCameraState -0.476 -8.906 18.262 -0.098 -0.098 -0.098 -0.981 -0.168 -0.101 $kw(vtkTemp23) SetCameraState -8.602 -10.839 14.973 -0.098 -0.098 -0.098 -0.905 0.168 -0.391 $kw(vtkTemp23) SetCameraState -10.104 2.128 17.501 -0.098 -0.098 -0.098 -0.870 -0.117 -0.480 $kw(vtkTemp23) SetCameraState -2.418 -13.983 14.620 -0.098 -0.098 -0.098 -0.956 -0.122 -0.265 $kw(vtkTemp23) SetCameraState 6.615 15.813 -10.896 -0.098 -0.098 -0.098 0.938 -0.206 0.279 $kw(vtkTemp39) DrawOutline $kw(vtkTemp39) ColorByPointField {vorticity} 3 $kw(vtkTemp5) SetCurrentPVSourceCallback $kw(vtkTemp751) $kw(vtkTemp751) SetVisibility 0 $kw(vtkTemp751) SetVisibility 1 $kw(vtkTemp751) SetVisibility 0 $kw(vtkTemp5) SetCurrentPVSourceCallback $kw(vtkTemp751) $kw(vtkTemp5) SetCurrentPVSourceCallback {} $kw(vtkTemp751) DeleteCallback $kw(vtkTemp5) SetCurrentPVSourceCallback $kw(vtkTemp661) set kw(vtkTemp793) [$kw(vtkTemp5) CreatePVSource PointDataToCellData] set kw(vtkTemp801) [$kw(vtkTemp793) GetPVWidget {Input}] $kw(vtkTemp801) SetCurrentValue $kw(vtkTemp661) set kw(vtkTemp796) [$kw(vtkTemp793) GetPVWidget {PassPointData}] $kw(vtkTemp796) SetState 0 $kw(vtkTemp793) AcceptCallback $kw(vtkTemp5) SetCurrentPVSourceCallback $kw(vtkTemp793) $kw(vtkTemp793) SetVisibility 0 $kw(vtkTemp793) SetVisibility 1 $kw(vtkTemp5) SetCurrentPVSourceCallback {} $kw(vtkTemp793) DeleteCallback $kw(vtkTemp5) SetCurrentPVSourceCallback $kw(vtkTemp661) set kw(vtkTemp840) [$kw(vtkTemp5) CreatePVSource PVConnectivityFilter] set kw(vtkTemp845) [$kw(vtkTemp840) GetPVWidget {Input}] $kw(vtkTemp845) SetCurrentValue $kw(vtkTemp661) set kw(vtkTemp850) [$kw(vtkTemp5) GetPVColorMap {RegionId} 1] $kw(vtkTemp850) SetScalarBarTitle {RegionId} $kw(vtkTemp840) AcceptCallback $kw(vtkTemp23) SetCameraState 12.393 12.523 -10.072 -0.098 -0.098 -0.098 0.769 -0.327 0.550 set kw(vtkTemp928) [$kw(vtkTemp5) CreatePVSource Contour] set kw(vtkTemp975) [$kw(vtkTemp928) GetPVWidget {Input}] $kw(vtkTemp975) SetCurrentValue $kw(vtkTemp840) set kw(vtkTemp976) [$kw(vtkTemp928) GetPVWidget {Scalars}] $kw(vtkTemp976) SetValue {RegionId} set kw(vtkTemp936) [$kw(vtkTemp928) GetPVWidget {Contour Values}] $kw(vtkTemp936) RemoveAllValues $kw(vtkTemp936) AddValue 0 set kw(vtkTemp962) [$kw(vtkTemp928) GetPVWidget {Compute Normals}] $kw(vtkTemp962) SetState 1 set kw(vtkTemp965) [$kw(vtkTemp928) GetPVWidget {Compute Gradients}] $kw(vtkTemp965) SetState 0 set kw(vtkTemp968) [$kw(vtkTemp928) GetPVWidget {Compute Scalars}] $kw(vtkTemp968) SetState 0 $kw(vtkTemp928) AcceptCallback $kw(vtkTemp840) SetVisibility 0 $kw(vtkTemp5) SetCurrentPVSourceCallback $kw(vtkTemp928) $kw(vtkTemp5) SetCurrentPVSourceCallback $kw(vtkTemp840) $kw(vtkTemp5) SetCurrentPVSourceCallback $kw(vtkTemp928) $kw(vtkTemp5) SetCurrentPVSourceCallback {} $kw(vtkTemp928) DeleteCallback $kw(vtkTemp5) SetCurrentPVSourceCallback $kw(vtkTemp840) $kw(vtkTemp5) SetCurrentPVSourceCallback $kw(vtkTemp840) set kw(vtkTemp1069) [$kw(vtkTemp5) CreatePVSource Calculator] set kw(vtkTemp1096) [$kw(vtkTemp1069) GetPVWidget {Input}] $kw(vtkTemp1096) SetCurrentValue $kw(vtkTemp840) set kw(vtkTemp1072) [$kw(vtkTemp1069) GetPVWidget {ResultArray}] $kw(vtkTemp1072) SetValue {Result} set kw(vtkTemp1078) [$kw(vtkTemp1069) GetPVWidget {Equation}] $kw(vtkTemp1078) ChangeAttributeMode {point} $kw(vtkTemp1078) AddScalarVariable {vorticity_0} {vorticity} 0 $kw(vtkTemp1078) AddScalarVariable {vorticity_1} {vorticity} 1 $kw(vtkTemp1078) AddScalarVariable {vorticity_2} {vorticity} 2 $kw(vtkTemp1078) AddScalarVariable {RegionId} {RegionId} 0 $kw(vtkTemp1078) AddVectorVariable {vorticity} {vorticity} $kw(vtkTemp1078) SetFunctionLabel {mag(vorticity)} set kw(vtkTemp1086) [$kw(vtkTemp1069) GetPVWidget {ReplaceInvalidValues}] $kw(vtkTemp1086) SetState 1 set kw(vtkTemp1089) [$kw(vtkTemp1069) GetPVWidget {ReplacementValue}] $kw(vtkTemp1089) SetValue 0 set kw(vtkTemp1101) [$kw(vtkTemp5) GetPVColorMap {Result} 1] $kw(vtkTemp1101) SetScalarBarTitle {Result} $kw(vtkTemp1069) AcceptCallback $kw(vtkTemp23) SetCameraState 1.557 17.788 9.501 -0.098 -0.098 -0.098 0.582 -0.426 0.693 $kw(vtkTemp23) SetCameraState -0.373 11.102 16.911 -0.098 -0.098 -0.098 0.569 -0.682 0.459 $kw(vtkTemp23) SetCameraState -9.792 10.306 14.482 -0.098 -0.098 -0.098 0.571 -0.439 0.693 set kw(vtkTemp1193) [$kw(vtkTemp5) CreatePVSource Contour] set kw(vtkTemp1242) [$kw(vtkTemp1193) GetPVWidget {Input}] $kw(vtkTemp1242) SetCurrentValue $kw(vtkTemp1069) set kw(vtkTemp1243) [$kw(vtkTemp1193) GetPVWidget {Scalars}] $kw(vtkTemp1243) SetValue {Result} set kw(vtkTemp1201) [$kw(vtkTemp1193) GetPVWidget {Contour Values}] $kw(vtkTemp1201) RemoveAllValues $kw(vtkTemp1201) AddValue 0.7486 set kw(vtkTemp1227) [$kw(vtkTemp1193) GetPVWidget {Compute Normals}] $kw(vtkTemp1227) SetState 1 set kw(vtkTemp1230) [$kw(vtkTemp1193) GetPVWidget {Compute Gradients}] $kw(vtkTemp1230) SetState 0 set kw(vtkTemp1233) [$kw(vtkTemp1193) GetPVWidget {Compute Scalars}] $kw(vtkTemp1233) SetState 0 $kw(vtkTemp1193) AcceptCallback $kw(vtkTemp1069) SetVisibility 0 $kw(vtkTemp5) SetCurrentPVSourceCallback $kw(vtkTemp1193) $kw(vtkTemp23) SetCameraState -3.619 17.396 9.719 -0.098 -0.098 -0.098 0.868 -0.099 0.487 $kw(vtkTemp23) SetCameraState -20.084 0.109 3.817 -0.098 -0.098 -0.098 0.115 0.833 0.541 $kw(vtkTemp23) SetCameraState 6.506 -13.346 13.891 -0.098 -0.098 -0.098 0.011 0.729 0.685 $kw(vtkTemp23) SetCameraState 3.168 -13.301 15.062 -0.098 -0.098 -0.098 -0.133 0.733 0.667 $kw(vtkTemp23) SetCameraState -12.822 -15.098 -5.381 -0.098 -0.098 -0.098 -0.371 -0.012 0.929 $kw(vtkTemp23) SetCameraState -20.465 -0.056 -0.192 -0.098 -0.098 -0.098 -0.004 0.127 0.992 $kw(vtkTemp23) SetCameraState -14.864 4.326 13.214 -0.098 -0.098 -0.098 0.676 0.046 0.735 $kw(vtkTemp23) SetCameraState 14.001 14.083 3.765 -0.098 -0.098 -0.098 0.714 -0.699 -0.042 $kw(vtkTemp23) SetCameraState -17.465 -4.265 9.693 -0.098 -0.098 -0.098 0.406 0.319 0.856 $kw(vtkTemp23) SetCameraState -15.169 2.998 13.247 -0.098 -0.098 -0.098 0.553 0.693 0.463 $kw(vtkTemp5) SetCurrentPVSourceCallback $kw(vtkTemp661) $kw(vtkTemp5) SetCurrentPVSourceCallback {} $kw(vtkTemp1193) DeleteCallback $kw(vtkTemp5) SetCurrentPVSourceCallback $kw(vtkTemp661) $kw(vtkTemp5) SetCurrentPVSourceCallback {} $kw(vtkTemp1069) DeleteCallback $kw(vtkTemp5) SetCurrentPVSourceCallback $kw(vtkTemp661) $kw(vtkTemp5) SetCurrentPVSourceCallback {} $kw(vtkTemp840) DeleteCallback $kw(vtkTemp5) SetCurrentPVSourceCallback $kw(vtkTemp661) $kw(vtkTemp5) SetCurrentPVSourceCallback {} $kw(vtkTemp661) DeleteCallback $kw(vtkTemp5) SetCurrentPVSourceCallback {} set kw(vtkTemp1404) [$kw(vtkTemp5) InitializeReadCustom "legacyreader" "C:/dan/research/wavelet_code/wlt_3d_V2/results/smalltest1_cn_adaptive.0001_vorticity.vtk"] # Error or warning: # There was a VTK Error in file: C:\dev\ParaView20\VTK\Parallel\vtkPDataSetReader.cxx (884) # Initialize: Could not open file C:/dan/research/wavelet_code/wlt_3d_V2/results/smalltest1_cn_adaptive.0001_vorticity.vtk # set kw(vtkTemp1418) [$kw(vtkTemp5) GetAnimationManager] set kw(vtkTemp483) [$kw(vtkTemp1418) GetAnimationScene] $kw(vtkTemp483) Stop # Error or warning: # There was a VTK Error in file: C:\dev\ParaView20\VTK\Filtering\vtkExecutive.cxx (652) # Algorithm vtkPDataSetReader(0F1E2530) returned failure for request: vtkInformation (0F20A8D0) # Debug: Off # Modified Time: 2286636 # Reference Count: 1 # Registered Events: (none) # REQUEST_DATA_OBJECT: 1 # ALGORITHM_AFTER_FORWARD: 1 # FORWARD_DIRECTION: 0 # $kw(vtkTemp483) Stop $kw(vtkTemp5) ReadFileInformation $kw(vtkTemp1404) "C:/dan/research/wavelet_code/wlt_3d_V2/results/smalltest1_cn_adaptive.0001_vorticity.vtk" $kw(vtkTemp5) FinalizeRead $kw(vtkTemp1404) "C:/dan/research/wavelet_code/wlt_3d_V2/results/smalltest1_cn_adaptive.0001_vorticity.vtk" # Error or warning: # There was a VTK Error in file: C:\dev\ParaView20\VTK\Parallel\vtkPDataSetReader.cxx (884) # Initialize: Could not open file C:/dan/research/wavelet_code/wlt_3d_V2/results/smalltest1_cn_adaptive.0001_vorticity.vtk # $kw(vtkTemp483) Stop # Error or warning: # There was a VTK Error in file: C:\dev\ParaView20\VTK\Filtering\vtkExecutive.cxx (652) # Algorithm vtkPDataSetReader(0F1E2530) returned failure for request: vtkInformation (0F2224D8) # Debug: Off # Modified Time: 2287012 # Reference Count: 1 # Registered Events: (none) # REQUEST_DATA_OBJECT: 1 # ALGORITHM_AFTER_FORWARD: 1 # FORWARD_DIRECTION: 0 # $kw(vtkTemp483) Stop # Error or warning: # There was a VTK Error in file: C:\dev\ParaView20\VTK\Parallel\vtkPDataSetReader.cxx (884) # Initialize: Could not open file C:/dan/research/wavelet_code/wlt_3d_V2/results/smalltest1_cn_adaptive.0001_vorticity.vtk # $kw(vtkTemp483) Stop # Error or warning: # There was a VTK Error in file: C:\dev\ParaView20\VTK\Filtering\vtkExecutive.cxx (652) # Algorithm vtkPDataSetReader(0F1E2530) returned failure for request: vtkInformation (1760B5E8) # Debug: Off # Modified Time: 2287130 # Reference Count: 1 # Registered Events: (none) # REQUEST_DATA_OBJECT: 1 # ALGORITHM_AFTER_FORWARD: 1 # FORWARD_DIRECTION: 0 # $kw(vtkTemp483) Stop # Error or warning: # There was a VTK Error in file: C:\dev\ParaView20\Servers\Common\vtkProcessModule.cxx (183) # Object tcl name must be wrong. # $kw(vtkTemp483) Stop # Error or warning: # There was a VTK Error in file: C:\dev\ParaView20\Servers\ServerManager\vtkSMPart.cxx (324) # Missing data information. # $kw(vtkTemp483) Stop # Error or warning: # There was a VTK Error in file: C:\dev\ParaView20\Servers\ServerManager\vtkSMPart.cxx (170) # Missing data information. # $kw(vtkTemp483) Stop # Error or warning: # There was a VTK Error in file: C:\dev\ParaView20\Servers\Common\vtkProcessModule.cxx (535) # Wrapper function not found for class "(vtk object is NULL)". # while processing # Message 0 = Invoke # Argument 0 = id_value {1651} # Argument 1 = string_value {UpdateInformation} # $kw(vtkTemp483) Stop # Error or warning: # There was a VTK Error in file: C:\dev\ParaView20\Servers\Common\vtkProcessModule.cxx (538) # Aborting execution for debugging purposes. # $kw(vtkTemp483) Stop | ||||||||
(0007795) Berk Geveci (administrator) 2007-06-02 14:06 |
No longer valid since state files are now xml. |
2009-12-09 14:50 | Berk Geveci | Project | @3@ => ParaView |
