0002346 | ParaView | (No Category) | public | 2005-10-07 14:29 | 2007-01-22 18:41 | ||||
Reporter | Brian Wylie | ||||||||
Priority | urgent | Severity | feature | Reproducibility | always | ||||
Summary | 0002346: Smart file sequence determination | ||||||||
Description | The remote file dialog will need a fast, robust way to determining file 'sequences' for data types with numbered files (exodus, spcth, etc). Also ParaQ will need the same functionality when loading 'local' data. Please note, this capability should handle 10000 files. | ||||||||
(0005979) Utkarsh Ayachit (administrator) 2006-12-14 09:59 |
Adding new framework to obtain directory listings or file information. Changed from a information properties on proxy based approach to Information object based one. This also includes soln for Bug 0002346. Since server side now detects patterns in files, it can not stat all files matching a pattern. Changed pqServerFileDialogModel to use the new vtkPVInformation instead of vtkPVServerFileListing. /cvsroot/ParaView3/ParaView3/Servers/Common/vtkPVFileInformation.cxx,v <-- vtkPVFileInformation.cxx initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/Common/vtkPVFileInformation.h,v <-- vtkPVFileInformation.h initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/Common/vtkPVFileInformationHelper.cxx,v <-- vtkPVFileInformationHelper.cxx initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/Common/vtkPVFileInformationHelper.h,v <-- vtkPVFileInformationHelper.h initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/utilities.xml,v <-- utilities.xml new revision: 1.71; previous revision: 1.70 /cvsroot/ParaView3/ParaView3/Qt/Components/pqServerFileDialogModel.cxx,v <-- pqServerFileDialogModel.cxx new revision: 1.7; previous revision: 1.6 The GUI still needs to make use of the groupping provided by the server manager. |
(0006167) Clinton Stimpson (developer) 2007-01-12 16:12 |
GUI side grouping done. /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/XML/ParaViewReaders.xml,v <-- ParaViewReaders.xml new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/XML/ParaViewWriters.xml,v <-- ParaViewWriters.xml new revision: 1.2; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Core/pqFileDialog.cxx,v <-- pqFileDialog.cxx new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Qt/Core/pqFileDialogModel.cxx,v <-- pqFileDialogModel.cxx new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Qt/Core/pqReaderFactory.cxx,v <-- pqReaderFactory.cxx new revision: 1.8; previous revision: 1.7 /cvsroot/ParaView3/ParaView3/Qt/Core/Resources/UI/pqFileDialog.ui,v <-- pqFileDialog.ui new revision: 1.2; previous revision: 1.1 |
(0006193) Ken Moreland (manager) 2007-01-16 11:52 |
Everything is working pretty good, except that the file does not expand on Windows. That is, if you press the '+' button, there is no expanson to show the individual files. It is a minor problem, but should be fixed nonetheless. It works fine on Mac and Linux. |
(0006200) Clinton Stimpson (developer) 2007-01-16 14:26 |
You probably have an extra ui_pqFileDialog.h file in Qt/Widgets or something (it used to live there). |
(0006202) Clinton Stimpson (developer) 2007-01-16 15:19 |
Verified it on my windows build. Removing pv3builddir/Qt/Widgets/ui_pqFileDialog.h and rebuilding pqCore fixed the problem. |
(0006236) Ken Moreland (manager) 2007-01-22 18:41 |
That did the trick for me, too. |
