0003304 | ParaView | (No Category) | public | 2006-05-31 16:56 | 2009-12-09 14:51 | ||||
Reporter | Brian Wylie | ||||||||
Assigned To | Dave DeMarle | ||||||||
Priority | high | Severity | major | Reproducibility | unable to reproduce | ||||
Status | closed | Resolution | unable to reproduce | ||||||
Summary | 0003304: SNL: Off screen rendering does not work with compositing | ||||||||
Description | Currently the off-screen rendering (making a movie) does not work when compositing is on. The problem is that this is when you want it to work the MOST. You have a BIG dataset you don't want to wait around 2 hours. So you do other stuff or leave your screen saver on. This needs to be fixed soon (yes I know there are issues...) | ||||||||
(0005665) user521 2006-11-07 12:58 |
I believe that Francois' recent changes have fixed this. My setup was to: run two pvserver processes with --use-offscreen-rendering and one pvclient. Make a 10^3 mandelbrot, contour it and animate the fractal's origin_cx from 0 to 1. Lastly I save the animation as an avi file through ffmpeg. When I compiled on linux using the latest nvidia drivers everything looks fine. When I use the paraview code from 5-31, when compositing is enabled the only thing in the render window is the axis widget. Using mesa with OSmesa works in either the current or 5-31 code. Let me know if this is not the behavior you saw back then or if the code still appears to be broken for you. |
