0003438 | ParaView | (No Category) | public | 2006-06-23 15:58 | 2009-12-09 14:51 | ||||
Reporter | Wendy Doyle | ||||||||
Summary | 0003438: SNL: VTK_USE_X missing on Mac and compile failing | ||||||||
Description | This applies to a cvs checkout. I use ccmake to configure, and the option VTK_USE_X is no longer showing up. Compile fails unless I manually add VTK_USE_X:BOOL=ON to CMakeCache.txt. The change that caused this happened sometime between 6/12 and 6/21/2006. I wonder if someone was trying to change the default settings for Mac to use X (which would be very nice). | ||||||||
(0004933) Wendy Doyle (reporter) 2006-09-15 16:51 |
Changes to ParaView has fixed this, so I'm closing it. |
