0003712 | ParaView | (No Category) | public | 2006-09-04 13:48 | 2007-04-03 17:48 | ||||
Reporter | Berk Geveci | ||||||||
Assigned To | Dave DeMarle | ||||||||
Summary | 0003712: Selection in superquadric is incorrect | ||||||||
Description | To reproduce: * Create a superquadric * Select some cells from it | ||||||||
(0006739) Berk Geveci (administrator) 2007-03-12 15:59 |
This may be related to triangle strips. |
(0006822) user521 2007-03-16 16:29 |
vtkExtractCells will segfault when it is given out of range ids. I stopped using that in vtkExtractSelectedIds and it no longer crashes. Unfortunately it still doesn't select the right cells. |
(0007070) user521 2007-04-02 17:03 |
I changed the IdentColoredPainter to match the cell list in the vtkOriginalCellIds list. Selection on polydata that includes strips, like the SuperQuadric filter produces, is now correct. I've opened bug 4758 to capture the fact that turning on stripping makes selection fail because the ids list and the rendered id's do not match. |
