0003867 | ParaView | (No Category) | public | 2006-10-06 17:22 | 2006-12-01 12:52 | ||||
Priority | urgent | Severity | major | Reproducibility | always | ||||
Summary | 0003867: Adding filter turns off visibility of input in all windows | ||||||||
Description | This bug occurs when you have multiple windows showing the same object in the pipeline. When two views show the same object, and then a filter is added to the object (such as clip), the selected view gets the result of the new filter (as expected), but the visibility of the object is turned off in the other view. | ||||||||
(0005852) Utkarsh Ayachit (administrator) 2006-12-01 12:52 |
ENH: Fixes BUG 0003868, 0003896, 0003867. When a pending display is added, we now hide the input's display in the active view. Also when a filter is deleted, we check for visibility of input in all the views that the filter was visible. If in any view the input is not visible, we turn its visibilty on. /cvsroot/ParaView3/ParaView3/Qt/Components/pqClipPanel.cxx,v <-- pqClipPanel.cxx new revision: 1.16; previous revision: 1.15 /cvsroot/ParaView3/ParaView3/Qt/Components/pqCutPanel.cxx,v <-- pqCutPanel.cxx new revision: 1.16; previous revision: 1.15 /cvsroot/ParaView3/ParaView3/Qt/Core/CMakeLists.txt,v <-- CMakeLists.txt new revision: 1.30; previous revision: 1.29 /cvsroot/ParaView3/ParaView3/Qt/Core/pqApplicationCore.cxx,v <-- pqApplicationCore.cxx new revision: 1.40; previous revision: 1.39 /cvsroot/ParaView3/ParaView3/Qt/Core/pqPendingDisplayManager.cxx,v <-- pqPendingDisplayManager.cxx new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Qt/Core/pqPipelineFilter.cxx,v <-- pqPipelineFilter.cxx new revision: 1.2; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Core/pqPipelineFilter.h,v <-- pqPipelineFilter.h new revision: 1.2; previous revision: 1.1 |
