0003869 | ParaView | (No Category) | public | 2006-10-06 17:28 | 2007-10-02 11:27 | ||||
Summary | 0003869: New pipeline browser icons | ||||||||
Description | We need better descriptive icons in the pipeline browser. The icons should give visual cues as to what type of view can be used with the particular filter. Thus get rid of the teardrop (source) and filter icons. Right now there are two types of views. There is a 3D geometry view. The corresponding icon should be a simple 3D structure (rotated, shaded cylinder?). There is also a plot view. The corresponding icon should be a little plot. | ||||||||
(0006944) Berk Geveci (administrator) 2007-03-27 10:15 |
I removed the source/filter/custom filter icons by commenting them out. I don't think we have time to add the logic for the display-based icons so I will reduce this to 3. |
(0007770) Berk Geveci (administrator) 2007-06-02 08:51 |
We need to figure out what we will do with these icons. |
(0009027) Utkarsh Ayachit (administrator) 2007-09-17 13:07 |
Added support to choose icons based on preferred view type. However, in absence of icons, using the old filter icons for the plot views. /cvsroot/ParaView3/ParaView3/Qt/Core/pqDisplayPolicy.h,v <-- pqDisplayPolicy.h new revision: 1.8; previous revision: 1.7 /cvsroot/ParaView3/ParaView3/Qt/Core/pqDisplayPolicy.cxx,v <-- pqDisplayPolicy.cxx new revision: 1.25; previous revision: 1.24 /cvsroot/ParaView3/ParaView3/Qt/Components/pqPipelineModel.cxx,v <-- pqPipelineModel.cxx new revision: 1.16; previous revision: 1.15 |
(0009033) Utkarsh Ayachit (administrator) 2007-09-17 16:44 |
I reverted the commit following some update issue. |
(0009325) Utkarsh Ayachit (administrator) 2007-09-28 11:09 |
Fixed progress issues surfaced by fix for BUG 0003869. Avoid recursive progress updates. /cvsroot/ParaView3/ParaView3/Qt/Core/pqDisplayPolicy.cxx,v <-- pqDisplayPolicy.cxx new revision: 1.29; previous revision: 1.28 /cvsroot/ParaView3/ParaView3/Qt/Core/pqProgressManager.cxx,v <-- pqProgressManager.cxx new revision: 1.5; previous revision: 1.4 /cvsroot/ParaView3/ParaView3/Qt/Core/pqProgressManager.h,v <-- pqProgressManager.h new revision: 1.3; previous revision: 1.2 |
2007-09-11 14:00 | Berk Geveci | Assigned To | Yumin Yuan => Utkarsh Ayachit |
2007-09-17 13:07 | Utkarsh Ayachit | Status | tabled => @80@ |
2007-09-17 13:07 | Utkarsh Ayachit | Resolution | open => fixed |
2007-09-17 13:07 | Utkarsh Ayachit | Note Added: 0009027 | |
2007-09-17 16:43 | Utkarsh Ayachit | Status | @80@ => @20@ |
2007-09-17 16:43 | Utkarsh Ayachit | Resolution | fixed => reopened |
2007-09-17 16:44 | Utkarsh Ayachit | Status | @20@ => tabled |
2007-09-17 16:44 | Utkarsh Ayachit | Note Added: 0009033 | |
2007-09-28 11:09 | Utkarsh Ayachit | Status | tabled => @80@ |
2007-09-28 11:09 | Utkarsh Ayachit | Resolution | reopened => fixed |
2007-09-28 11:09 | Utkarsh Ayachit | Note Added: 0009325 | |
2007-10-02 11:27 | Ken Moreland | Status | @80@ => closed |
