0003936 | ParaView | (No Category) | public | 2006-10-12 09:46 | 2007-09-21 14:06 | ||||
Status | closed | Resolution | not fixable | ||||||
Summary | 0003936: Off by one pixel multiview windows | ||||||||
Description | When you are in client server mode and are doing image compositing, there is sometimes an off-by-one error that occurs when reading back images when you have multiple windows. Sometimes on the left and/or bottom there is a pixel-width worth of image read back that is garbage. The arithmetic in vtkPVDesktopDeliveryServer is probably wrong. My guess is that it is computing the offset of the viewports to be a little too far to the upper left. | ||||||||
(0008432) Berk Geveci (administrator) 2007-08-13 15:17 |
Ken, can you verify if this is still the case? |
(0009025) Ken Moreland (manager) 2007-09-17 11:55 |
Sometimes if I crank up the subsample rate and/or resize the window a lot, I can see some errors around the view edges during interactive rendering. But overall it looks fine. I am not opposed to closing this bug. |
2007-08-13 15:16 | Berk Geveci | Assigned To | Utkarsh Ayachit => Ken Moreland |
2007-08-13 15:17 | Berk Geveci | Note Added: 0008432 | |
2007-08-13 15:17 | Berk Geveci | Priority | normal => high |
2007-09-17 11:44 | Berk Geveci | Assigned To | Ken Moreland => Utkarsh Ayachit |
2007-09-17 11:55 | Ken Moreland | Note Added: 0009025 | |
2007-09-17 16:48 | Utkarsh Ayachit | Note Added: 0009034 | |
2007-09-19 09:26 | Utkarsh Ayachit | Note Deleted: 0009034 | |
2007-09-19 09:27 | Utkarsh Ayachit | Status | tabled => @80@ |
2007-09-19 09:27 | Utkarsh Ayachit | Resolution | open => not fixable |
2007-09-21 14:06 | Alan Scott | Status | @80@ => closed |
