0003943 | ParaView | (No Category) | public | 2006-10-16 09:17 | 2007-04-02 11:18 | ||||
Summary | 0003943: Use "builtin" when disconnected | ||||||||
Description | To use ParaView 3 in standalone mode, the user must "connect" to a "builtin" server. On reflection, I don't think this is the right thing to do. Besides being a somewhat unnecessary extra step, it can lead to user confusion. If not connecting to a server, it's not intuitive that we have to go through the motions of connecting to a server. This issue a small part of a larger issue concerning integrating client/server connections with the file browser to make the mechanism more usable. | ||||||||
(0006743) Berk Geveci (administrator) 2007-03-12 16:06 |
There should also be no connect dialog when starting up. It should automatically connect to builtin. |
(0006898) Utkarsh Ayachit (administrator) 2007-03-22 09:47 |
Now there is always a builtin connection connected. User can always connect to new server, even when the client is already connected to a server. If there are any sources created, we show a warning, otherwise the old connection is closed before connecting to the new one. /cvsroot/ParaView3/ParaView3/Qt/Components/pqMainWindowCore.cxx,v <-- pqMainWindowCore.cxx new revision: 1.138; previous revision: 1.137 /cvsroot/ParaView3/ParaView3/Qt/Components/pqServerStartupBrowser.cxx,v <-- pqServerStartupBrowser.cxx new revision: 1.3; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Qt/Components/pqSimpleServerStartup.cxx,v <-- pqSimpleServerStartup.cxx new revision: 1.12; previous revision: 1.11 /cvsroot/ParaView3/ParaView3/Qt/Components/pqSimpleServerStartup.h,v <-- pqSimpleServerStartup.h new revision: 1.5; previous revision: 1.4 /cvsroot/ParaView3/ParaView3/Qt/Core/pqApplicationCore.h,v <-- pqApplicationCore.h new revision: 1.27; previous revision: 1.26 /cvsroot/ParaView3/ParaView3/Qt/Core/pqProcessModuleGUIHelper.cxx,v <-- pqProcessModuleGUIHelper.cxx new revision: 1.15; previous revision: 1.14 /cvsroot/ParaView3/ParaView3/Qt/Core/pqUndoStack.cxx,v <-- pqUndoStack.cxx new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Applications/Client/MainWindow.cxx,v <-- MainWindow.cxx new revision: 1.95; previous revision: 1.94 /cvsroot/ParaView3/ParaView3/Applications/Client/Testing/Python/LoadStateMultiView.py,v <-- LoadStateMultiView.py new revision: 1.10; previous revision: 1.9 /cvsroot/ParaView3/ParaView3/Applications/Client/Testing/XML/CreateSourceWithoutConnect.xml,v <-- CreateSourceWithoutConnect.xml new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Applications/Client/Testing/XML/ImageShrink.xml,v <-- ImageShrink.xml new revision: 1.5; previous revision: 1.4 /cvsroot/ParaView3/ParaView3/Applications/Client/Testing/XML/LoadStateHistogram.xml,v <-- LoadStateHistogram.xml new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/Applications/Client/Testing/XML/OpenFile.xml,v <-- OpenFile.xml new revision: 1.9; previous revision: 1.8 /cvsroot/ParaView3/ParaView3/Applications/Client/Testing/XML/OpenSaveData.xml,v <-- OpenSaveData.xml new revision: 1.11; previous revision: 1.10 /cvsroot/ParaView3/ParaView3/Applications/Client/Testing/XML/PropertyLink.xml,v <-- PropertyLink.xml new revision: 1.2; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Applications/Client/Testing/XML/SimpleInteraction.xml,v <-- SimpleInteraction.xml new revision: 1.10; previous revision: 1.9 /cvsroot/ParaView3/ParaView3/Applications/Client/Testing/XML/ViewSettingsDialog.xml,v <-- ViewSettingsDialog.xml new revision: 1.8; previous revision: 1.7 |
