0003947 | ParaView | (No Category) | public | 2006-10-17 06:54 | 2009-12-09 21:22 | ||||
Reporter | Erik Edelmann | ||||||||
Priority | low | Severity | minor | Reproducibility | always | ||||
Summary | 0003947: Seg. Fault with .pvd + .vtk (legacy) | ||||||||
Description | I have e bunch of .vtk (legacy) files. Reading them directly into paraview, e.g. > paraview --data=mooo0001.vtk works well. But if I write a .pvd header file for them, and feed that file to paraview; > paraview --data=mooo.pvd paraview crashes with Segmentation fault. If I convert the *.vtk files to the newer XML based format by opening them in paraview and saving them as .vtu, and read these .vtu files via a .pvd file, it works, so it seems that it's reading legacy .vtk files via a .pvd file that is broken. I'm using paraview 2.4.4 on Linux/x86. | ||||||||
Attached Files | mooo.tar [^] (266,240 bytes) 1969-12-31 19:00 | ||||||||
(0005493) Erik Edelmann (reporter) 2006-10-23 09:12 |
Ok, after reading the fine print in the manual, I realize that this isn't supposed to work. Some more user friendly error message than "Segmentation fault" would still be nice. |
2009-12-09 21:22 | Berk Geveci | Status | tabled => closed |
2009-12-09 21:22 | Berk Geveci | Resolution | open => fixed |
