0004119 | ParaView | (No Category) | public | 2006-12-01 10:30 | 2007-04-03 18:15 | ||||
Summary | 0004119: Cell/point id based picking | ||||||||
Description | ParaView 2 allows you to pick a cell or point based on id. ParaView 3 needs to do that, too. | ||||||||
(0006565) user521 2007-02-26 17:03 |
I added ID picking for selection today. It is not finished yet. In particular it does not do point ID picking yet, it does use globalids yet, and the GUI to use it is in rough draft state. Howevert the code path to do ID selection is in and can be used to start prototyping analysis. |
(0006821) user521 2007-03-16 15:51 |
Point and cell extraction by id is now in. To use it make up a vtkSelection with CONTENT_TYPE=IDS, FIELD_TYPE=POINT or CELL, and an optional ARRAY_NAME and the extract filter will give you whatever cells or points that you request. |
(0006830) Ken Moreland (manager) 2007-03-19 10:47 |
I'm not seeing how this is reflected in the PV 3 GUI, and thus I don't see how this is implementing the functionality from PV 2. How does the user pick a point/cell by id, get its data values, see its position in a 3D view, and plot the value over time? |
(0006866) Ken Moreland (manager) 2007-03-20 13:49 |
We need to access this from the GUI. |
(0007008) Berk Geveci (administrator) 2007-03-29 14:12 |
Utkarsh is working on this. |
