0004133 | ParaView | (No Category) | public | 2006-12-04 18:58 | 2011-01-13 17:00 | ||||
Summary | 0004133: Selecting blocks | ||||||||
Description | In addition to selecting individual points or cells, it should be possible to select any block under the rubber band (or click) in a multiblock data set. | ||||||||
Relationships | |||||||||||
(0011276) Utkarsh Ayachit (administrator) 2008-04-14 11:55 |
Added support to select blocks of a multiblock dataset. Use the shortcut "B" to enter the block-selection mode and then draw the rubber band or simply click to select the block at the cursor. Added a new ContentType (BLOCKS) to vtkSelection. In this mode, the vtkSelectionList is a vtkUnsignedIntArray with the composite index for the selected blocks. /cvsroot/ParaView3/ParaView3/Applications/Client/MainWindow.cxx,v <-- Applications/Client/MainWindow.cxx new revision: 1.140; previous revision: 1.139 /cvsroot/ParaView3/ParaView3/Applications/Client/MainWindow.h,v <-- Applications/Client/MainWindow.h new revision: 1.27; previous revision: 1.26 /cvsroot/ParaView3/ParaView3/Applications/Client/MainWindow.ui,v <-- Applications/Client/MainWindow.ui new revision: 1.96; previous revision: 1.95 /cvsroot/ParaView3/ParaView3/Qt/Components/pqExtractSelectionsPanel.cxx,v <-- Qt/Components/pqExtractSelectionsPanel.cxx new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Qt/Components/pqSelectionInspectorPanel.cxx,v <-- Qt/Components/pqSelectionInspectorPanel.cxx new revision: 1.24; previous revision: 1.23 /cvsroot/ParaView3/ParaView3/Qt/Components/pqSelectionInspectorPanel.h,v <-- Qt/Components/pqSelectionInspectorPanel.h new revision: 1.15; previous revision: 1.14 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqSelectionInspectorPanel.ui,v <-- Qt/Components/Resources/UI/pqSelectionInspectorPanel.ui new revision: 1.13; previous revision: 1.12 /cvsroot/ParaView3/ParaView3/Qt/Core/pqRenderView.cxx,v <-- Qt/Core/pqRenderView.cxx new revision: 1.33; previous revision: 1.32 /cvsroot/ParaView3/ParaView3/Qt/Core/pqRenderView.h,v <-- Qt/Core/pqRenderView.h new revision: 1.16; previous revision: 1.15 /cvsroot/ParaView3/ParaView3/Qt/Core/pqRubberBandHelper.cxx,v <-- Qt/Core/pqRubberBandHelper.cxx new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Qt/Core/pqRubberBandHelper.h,v <-- Qt/Core/pqRubberBandHelper.h new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Qt/Core/pqSpreadSheetViewModel.cxx,v <-- Qt/Core/pqSpreadSheetViewModel.cxx new revision: 1.20; previous revision: 1.19 /cvsroot/ParaView3/ParaView3/Servers/Common/vtkSelectionConverter.cxx,v <-- Servers/Common/vtkSelectionConverter.cxx new revision: 1.15; previous revision: 1.14 /cvsroot/ParaView3/ParaView3/Servers/Common/vtkSelectionConverter.h,v <-- Servers/Common/vtkSelectionConverter.h new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkIndexBasedBlockSelectionFilter.cxx,v <-- Servers/Filters/vtkIndexBasedBlockSelectionFilter.cxx new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPVExtractSelection.cxx,v <-- Servers/Filters/vtkPVExtractSelection.cxx new revision: 1.10; previous revision: 1.9 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPVExtractSelection.h,v <-- Servers/Filters/vtkPVExtractSelection.h new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPVSelectionSource.cxx,v <-- Servers/Filters/vtkPVSelectionSource.cxx new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPVSelectionSource.h,v <-- Servers/Filters/vtkPVSelectionSource.h new revision: 1.2; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMSelectionHelper.cxx,v <-- Servers/ServerManager/vtkSMSelectionHelper.cxx new revision: 1.13; previous revision: 1.12 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMSelectionHelper.h,v <-- Servers/ServerManager/vtkSMSelectionHelper.h new revision: 1.5; previous revision: 1.4 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/sources.xml,v <-- Servers/ServerManager/Resources/sources.xml new revision: 1.81; previous revision: 1.80 /cvsroot/ParaView3/ParaView3/VTK/Filtering/vtkSelection.cxx,v <-- VTK/Filtering/vtkSelection.cxx new revision: 1.25; previous revision: 1.24 /cvsroot/ParaView3/ParaView3/VTK/Filtering/vtkSelection.h,v <-- VTK/Filtering/vtkSelection.h new revision: 1.34; previous revision: 1.33 /cvsroot/ParaView3/ParaView3/VTK/Graphics/CMakeLists.txt,v <-- VTK/Graphics/CMakeLists.txt new revision: 1.179; previous revision: 1.178 /cvsroot/ParaView3/ParaView3/VTK/Graphics/vtkConvertSelection.cxx,v <-- VTK/Graphics/vtkConvertSelection.cxx new revision: 1.13; previous revision: 1.12 /cvsroot/ParaView3/ParaView3/VTK/Graphics/vtkConvertSelection.h,v <-- VTK/Graphics/vtkConvertSelection.h new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/VTK/Graphics/vtkExtractSelectedBlock.cxx,v <-- VTK/Graphics/vtkExtractSelectedBlock.cxx initial revision: 1.1 /cvsroot/ParaView3/ParaView3/VTK/Graphics/vtkExtractSelectedBlock.h,v <-- VTK/Graphics/vtkExtractSelectedBlock.h initial revision: 1.1 /cvsroot/ParaView3/ParaView3/VTK/Graphics/vtkExtractSelection.cxx,v <-- VTK/Graphics/vtkExtractSelection.cxx new revision: 1.23; previous revision: 1.22 /cvsroot/ParaView3/ParaView3/VTK/Graphics/vtkExtractSelection.h,v <-- VTK/Graphics/vtkExtractSelection.h new revision: 1.12; previous revision: 1.11 /cvsroot/ParaView3/ParaView3/VTK/Graphics/vtkExtractSelectionBase.cxx,v <-- VTK/Graphics/vtkExtractSelectionBase.cxx new revision: 1.2; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/VTK/Graphics/vtkSelectionSource.cxx,v <-- VTK/Graphics/vtkSelectionSource.cxx new revision: 1.20; previous revision: 1.19 /cvsroot/ParaView3/ParaView3/VTK/Graphics/vtkSelectionSource.h,v <-- VTK/Graphics/vtkSelectionSource.h new revision: 1.11; previous revision: 1.10 |
(0011377) Alan Scott (manager) 2008-04-15 18:20 |
I believe that this does solve this bug, but it does not solve what are listed as duplicates. For instance, using can.exo, I would like to color the can by compositeIndex and the block by DISPL. Furthermore, I don't know which block is which, and I have lots of blocks, and don't want to randomly click in the "block Indeces". I would like to run an Extract Block filter, and select the can, color the can. Then, I want to reverse it - use the Extract Block filter, select everything other than the can, and color the rest of the stuff (the block). |
(0011392) Utkarsh Ayachit (administrator) 2008-04-16 10:40 |
You can use "Extract Selection" filter to select blocks to extract by picking them on the screen. Using selection inspector you can invert the selection as well. (I'll soon add capabilities to "Extract Selection" filter to invert the selection without going to the selection inspector) |
(0011422) Alan Scott (manager) 2008-04-17 19:36 |
OK, I agree with what you said in the note above. Next, it fails client/server. I get an output message as follows: \alan\paraviewNightlyTrunk\src\ParaView3\Servers\ServerManager\vtkSMSelectionHelper.cxx, line 209 Unhandled ContentType: 0 This was using can.exo. |
(0011456) Utkarsh Ayachit (administrator) 2008-04-21 11:54 |
Ah---there was a bug in parallel. Fixed that. /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMSelectionHelper.cxx,v <-- Servers/ServerManager/vtkSMSelectionHelper.cxx new revision: 1.14; previous revision: 1.13 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPConvertSelection.cxx,v <-- Servers/Filters/vtkPConvertSelection.cxx new revision: 1.2; previous revision: 1.1 |
(0011519) Alan Scott (manager) 2008-04-23 15:06 |
Tested client/server. |
2008-04-07 16:20 | Berk Geveci | Assigned To | Dave DeMarle => Utkarsh Ayachit |
2008-04-07 16:20 | Berk Geveci | Priority | low => high |
2008-04-07 16:20 | Berk Geveci | Category | => 3.4 |
2008-04-14 10:29 | Utkarsh Ayachit | Target Version | => Multi-block support |
2008-04-14 11:55 | Utkarsh Ayachit | Status | tabled => @80@ |
2008-04-14 11:55 | Utkarsh Ayachit | Resolution | open => fixed |
2008-04-14 11:55 | Utkarsh Ayachit | Note Added: 0011276 | |
2008-04-14 11:57 | Utkarsh Ayachit | Relationship added | has duplicate 0004926 |
2008-04-15 16:44 | Utkarsh Ayachit | Relationship added | has duplicate 0006522 |
2008-04-15 18:20 | Alan Scott | Status | @80@ => @20@ |
2008-04-15 18:20 | Alan Scott | Resolution | fixed => reopened |
2008-04-15 18:20 | Alan Scott | Note Added: 0011377 | |
2008-04-16 10:40 | Utkarsh Ayachit | Note Added: 0011392 | |
2008-04-17 19:36 | Alan Scott | Note Added: 0011422 | |
2008-04-21 11:54 | Utkarsh Ayachit | Status | @20@ => @80@ |
2008-04-21 11:54 | Utkarsh Ayachit | Resolution | reopened => fixed |
2008-04-21 11:54 | Utkarsh Ayachit | Note Added: 0011456 | |
2008-04-23 15:06 | Alan Scott | Status | @80@ => closed |
2008-04-23 15:06 | Alan Scott | Note Added: 0011519 | |
2009-05-13 13:58 | Utkarsh Ayachit | Target Version | Multi-block support => 3.4 |
2011-01-13 17:00 | Source_changeset_attached | => VTK master a2bd8391 | |
2011-01-13 17:00 | Source_changeset_attached | => VTK master 020ef709 | |
