0004197 | ParaView | (No Category) | public | 2006-12-12 19:35 | 2007-02-27 14:00 | ||||
Summary | 0004197: Bigger default point size | ||||||||
Description | We had a couple of users complain that when they had data with only vertex data, it was very hard to see anything unless there was a LOT of vertices. The problem is that when the data is only one pixel big, it is very difficult for users to resolve individual entities. The default point size should be big enough to see clearly. In our original users' case, they were unaware of the point size option, which compounded the problem. Still, the default value should allow you to see the cells. | ||||||||
(0006553) Ken Moreland (manager) 2007-02-23 10:52 |
Changed the default point size to 5. /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/rendering.xml,v <-- rendering.xml new revision: 1.137; previous revision: 1.136 |
