0004206 | ParaView | (No Category) | public | 2006-12-13 18:36 | 2009-12-09 21:55 | ||||
Reporter | Orion Poplawski | ||||||||
Summary | 0004206: cmake error with cmake 2.4.4 | ||||||||
Description | When trying to make an mpi version of paraview 2.4.4 with cmake 2.4.5 I get the following error: CMake Error: Error in cmake code at /builddir/build/BUILD/paraview-2.4.4/Utilities/IceT/doc/man/CMakeLists.txt:48: ADD_CUSTOM_TARGET called with invalid target name "man3/icetBoundingBoxd.3". Target names may not contain a slash. Use ADD_CUSTOM_COMMAND to generate files. Set CMAKE_BACKWARDS_COMPATIBILITY to 2.2 or lower to skip this check. Current CMake stack: /builddir/build/BUILD/paraview-2.4.4/Utilities/IceT/doc/man/CMakeLists.txt CMake Error: Error in cmake code at /builddir/build/BUILD/paraview-2.4.4/Utilities/IceT/doc/man/CMakeLists.txt:61: A command failed during the invocation of macro "ICET_LINK_MAN3_FILE". CMake Error: Error in cmake code at /builddir/build/BUILD/paraview-2.4.4/Utilities/IceT/doc/man/CMakeLists.txt:61: ICET_LINK_MAN3_FILE unknown error. Current CMake stack: /builddir/build/BUILD/paraview-2.4.4/Utilities/IceT/doc/man/CMakeLists.txt CMake Error: Error in cmake code at /builddir/build/BUILD/paraview-2.4.4/Utilities/IceT/doc/man/CMakeLists.txt:48: ADD_CUSTOM_TARGET called with invalid target name "man3/icetBoundingBoxf.3". Target names may not contain a slash. Use ADD_CUSTOM_COMMAND to generate files. Set CMAKE_BACKWARDS_COMPATIBILITY to 2.2 or lower to skip this check. [ many similar errors removed ] | ||||||||
(0006195) Orion Poplawski (reporter) 2007-01-16 12:00 |
I can't build paraview for Fedora Development until this gets addressed. Tried to change CMakeLists.txt to: MACRO(ICET_LINK_MAN3_FILE srcfile destfile) ADD_CUSTOM_COMMAND( OUTPUT man3/${destfile}.3 COMMAND ln ARGS -sf ${ICET_SOURCE_DIR}/doc/man/man3/${srcfile}.3 man3/${destfile}.3 DEPENDS man3) INSTALL_FILES(/man/man3 FILES ${ICET_BINARY_DIR}/doc/man/man3/${destfile}.3) ENDMACRO(ICET_LINK_MAN3_FILE) MACRO(ICET_LINK_MAN7_FILE srcfile destfile) ADD_CUSTOM_COMMAND( OUTPUT man7/${destfile}.7 COMMAND ln ARGS -sf ${ICET_SOURCE_DIR}/doc/man/man7/${srcfile}.7 man7/${destfile}.7 DEPENDS man7) INSTALL_FILES(/man/man7 FILES ${ICET_BINARY_DIR}/doc/man/man7/${destfile}.7) ENDMACRO(ICET_LINK_MAN7_FILE) But that doesn't seem to work. Using CMAKE_BACKWARDS_COMPATIBILITY=2.2 breaks other things. Please help! |
(0006608) Orion Poplawski (reporter) 2007-03-01 11:30 |
Also happens with paraview 2.6.0 and cmake 2.4.6. |
2009-12-09 21:55 | Berk Geveci | Status | tabled => closed |
2009-12-09 21:55 | Berk Geveci | Resolution | open => fixed |
