0004485 | ParaView | (No Category) | public | 2007-02-22 18:47 | 2007-02-26 14:42 | ||||
Summary | 0004485: Snap to each and every time step | ||||||||
Description | When the "Snap to TimeSteps" option is selected for the animation play mode, it does not actually snap to all of the time steps. Instead, you still need to enter the number of frames. Presumably the animator is snapping to the time steps, but it does not visit each one exactly once. When the "Snap to TimeSteps" option is selected, the "No. Of Frames" option should be greyed out, and the animation should visit every time step defined in the data. | ||||||||
(0006549) Utkarsh Ayachit (administrator) 2007-02-23 09:56 |
The "No. of Frames" was never actually used in "Snap To TimeSteps" mode. There was a mismatch between the text shown in the "Play Mode" combo and that in the enumeration domain for the property which was causing changing the play mode to "Snap To Timestep" have no effect. Consequently the "No. of Frames" or "Duration" depending on which was the last mode would be shown and used. Fixed that. |
