0004522 | ParaView | (No Category) | public | 2007-03-01 17:04 | 2009-12-09 14:51 | ||||
Assigned To | Amy Squillacote | ||||||||
Summary | 0004522: SNL: LOD sometimes does not work in client/server | ||||||||
Description | When running PV in client/server mode, the LOD often does not work. If you set the LOD threshold to 0 and then load in or generate any data, the interactive render still renders the full model. Some event may force the LOD to start working. Changing the LOD threshold sometimes does it. So can changing the parameters in the object inspector. I'm actually reporting this bug against version 2.6. It should be fixed by 2.6.1. However, the "Version" chooser box does not have 2.6 in it yet. | ||||||||
(0006681) Amy Squillacote (reporter) 2007-03-08 08:47 |
Hi Ken, I've committed a fix for this. (See below.) Please verify that you no longer see the problem. If that is the case, please change the status of this bug to closed. /cvsroot/ParaView/ParaView/GUI/Client/vtkPVSource.cxx,v <-- vtkPVSource.cxx new revision: 1.487.2.2; previous revision: 1.487.2.1 |
(0006703) Ken Moreland (manager) 2007-03-09 13:02 |
It looks correct now. |
