0004582 | ParaView | (No Category) | public | 2007-03-12 16:14 | 2007-08-13 16:28 | ||||
Reporter | Berk Geveci | ||||||||
Summary | 0004582: Empty views should have icons to select type | ||||||||
Description | When an empty view is created, it should have a series of buttons to set the type as well as some text explaining what to do. It should say that if you turn on the visibility of an object, the view will be created for you. See Tim/ThreatView for details. | ||||||||
(0007453) Ken Moreland (manager) 2007-04-24 18:53 |
The buttons have been added. When the icons for bug 0003896 are created, they can be added to the empty view buttons. The text explaining that a view will be automatically created when you make an object visible still needs to be added. |
2007-08-13 16:28 | Berk Geveci | Status | tabled => closed |
2007-08-13 16:28 | Berk Geveci | Resolution | open => fixed |
