0004596 | ParaView | (No Category) | public | 2007-03-14 09:28 | 2007-04-02 17:23 | ||||
Reporter | Berk Geveci | ||||||||
Summary | 0004596: Only some glyph source are supported | ||||||||
Description | Only some of the glyph sources from pv 2 are supported. The full list is: ArrowSource ConeSource CubeSource LineSource SphereSource GlyphSource2D and should all be supported. See pv 2. | ||||||||
(0006796) Clinton Stimpson (developer) 2007-03-14 16:44 |
Also, PV2 had global instances of those glyph sources. And one could modify them (e.g. sphere radius). We need the ability to access those parameters in PV3. So my plan is to create sub-panels within the object panels for those. Similar to how the stream tracer panel has sub-panels for the line/point seed types. |
(0006938) Clinton Stimpson (developer) 2007-03-26 17:25 |
Numerous commits were put in to support subpanels for proxies in a ProxyListDomain. Finally added the remaining glyph sources. /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/filters.xml,v <-- filters.xml new revision: 1.202; previous revision: 1.201 |
