0004606 | ParaView | (No Category) | public | 2007-03-15 14:43 | 2007-04-03 13:00 | ||||
Reporter | Timothy Shead | ||||||||
Assigned To | Dave DeMarle | ||||||||
Summary | 0004606: Problem loading state files containing programmable filters. | ||||||||
Description | * Start ParaView3 * Load a dataset * Add a programmable filter * Enter a Python program that contains "tab" characters. * Save the session state. * Restart ParaView3. * Load the previous session state. * See error messages from the XML parser: "ERROR: In \src\ParaView3\Vtk\Io\vtkXMLParser.cxx, line 442 vtkPVXMLParser (0F83ED30): Error parsing XML in stream at line 1542: reference to invalid character number Root does not exist. Either state file could not be opened or it does not contain valid xml" * Manually removing the encoded tab character(s) from the state file cause the errors to go away. | ||||||||
(0006927) user521 2007-03-23 14:57 |
My mistake. I used ascii for vtab instead of htab in vtkPVXMLElement.cxx. Committed fix. |
(0007103) Timothy Shead (reporter) 2007-04-03 12:38 |
Confirmed that this is fixed. Tim |
