0004609 | ParaView | (No Category) | public | 2007-03-15 18:35 | 2016-08-12 09:57 | ||||
Reporter | Scott Bardenhagen | ||||||||
Priority | low | Severity | major | Reproducibility | always | ||||
Summary | 0004609: Extract Grid Animation picks up wrong grid dimensions | ||||||||
Description | If I animate slicing through data by filtering through extractgrid and then, in keyframe animation, picking source: ExtractGrid0 Property: VOI:0 and then add key frame, then the min and max are correct for the x direction. VOI:1 also slices in the x direction, but it picks up the max/min y grid dimensions (apparently) It appears VOI:2 picks up z dimensions (should be y) etc. Things got mapped wrong. It's a "real" problem, because you can't input a value outside the max/min and hence can't slice through all data in some instances. | ||||||||
(0037512) Kitware Robot (administrator) 2016-08-12 09:57 |
2016-08-12 09:57 | Kitware Robot | Note Added: 0037512 | |
