0004690 | ParaView | (No Category) | public | 2007-03-27 09:57 | 2007-04-03 12:32 | ||||
Reporter | David Karelitz | ||||||||
Summary | 0004690: Default Threshold UI values not correct | ||||||||
Description | Both the high and low threshold values default to the same value which is not the value of the slider. This is when running in parallel | ||||||||
(0006945) Clinton Stimpson (developer) 2007-03-27 10:41 |
Apparently the server manager isn't giving the correct defaults. |
(0006969) Clinton Stimpson (developer) 2007-03-28 11:01 |
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMArrayRangeDomain.cxx,v <-- vtkSMArrayRangeDomain.cxx new revision: 1.12; previous revision: 1.11 |
