0004698 | ParaView | (No Category) | public | 2007-03-27 11:55 | 2011-01-13 17:00 | ||||
Reporter | David Karelitz | ||||||||
Summary | 0004698: D3 crashes | ||||||||
Description | I tried to run D3 on a 16 file dataset using 20 processors. D3 promptly caused the server to crash | ||||||||
(0006960) Berk Geveci (administrator) 2007-03-27 13:32 |
Dave will try this with paraview 2.6 to find out if this is a new bug. |
(0007090) Berk Geveci (administrator) 2007-04-03 09:47 |
Ken, can you track this down? |
(0007259) David Karelitz (reporter) 2007-04-12 13:16 |
After some debugging, this happens when the client is compiled with 32-bit ID's and the server is using 64-bit ID's |
(0007366) Ken Moreland (manager) 2007-04-18 10:58 |
The problem was that a struct with vtkIdType fields was being typecast to a similar struct with int fields. I changed the two variable instances to use the same declaration of the struct. /cvsroot/ParaView3/ParaView3/VTK/Parallel/vtkDistributedDataFilter.cxx,v <-- vtkDistributedDataFilter.cxx new revision: 1.43; previous revision: 1.42 |
2011-01-13 17:00 | Source_changeset_attached | => VTK master a2bd8391 | |
2011-01-13 17:00 | Source_changeset_attached | => VTK master 020ef709 | |
