0004739 | ParaView | (No Category) | public | 2007-03-30 17:03 | 2007-04-03 18:14 | ||||
Reporter | David Karelitz | ||||||||
Summary | 0004739: Switching to Wrapped HSV in new Color Scale Editor causes a segfault | ||||||||
Description | If you switch to Wrapped HSV color space in the new Color Scale Editor, ParaView segfaults: ERROR: In /home/projects/ParaView3-Trunk/ParaView3/VTK/Filtering/vtkColorTransferFunction.cxx, line 864 vtkColorTransferFunction (0xab22060): Index out of range! ERROR: In /home/projects/ParaView3-Trunk/ParaView3/VTK/Filtering/vtkColorTransferFunction.cxx, line 864 vtkColorTransferFunction (0xab22060): Index out of range! Segmentation fault | ||||||||
(0007088) Amy Squillacote (reporter) 2007-04-03 08:10 |
added a fix in vtkTransferFunctionEditorWidgetSimple1D.cxx - check the transfer functions for number of elements, not number of nodes in TFE (might be in the middle of updating TFE from the transfer functions). I think this fixes the problem, but Mark was in the middle of fixing the problem in a different location. /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkTransferFunctionEditorWidgetSimp le1D.cxx,v <-- vtkTransferFunctionEditorWidgetSimple1D.cxx new revision: 1.22; previous revision: 1.21 |
(0007105) Mark Richardson (reporter) 2007-04-03 12:41 |
I added a flag to prevent the dialog from reloading the color function when the color space is changed. I was unaware that setting the color space changed the rgb points. |
