0004802 | ParaView | (No Category) | public | 2007-04-05 14:51 | 2007-05-10 10:48 | ||||
Summary | 0004802: Reset camera cannot be undone | ||||||||
Description | Reset camera does not get saved on interaction undo stack. | ||||||||
(0007238) Utkarsh Ayachit (administrator) 2007-04-11 10:01 |
Reset camera gets saved on the undo stack. It also works fine with linked views and their undo stacks. /cvsroot/ParaView3/ParaView3/Qt/Core/pqRenderViewModule.cxx,v <-- pqRenderViewModule.cxx new revision: 1.47; previous revision: 1.46 /cvsroot/ParaView3/ParaView3/Qt/Core/pqRenderViewModule.h,v <-- pqRenderViewModule.h new revision: 1.22; previous revision: 1.21 |
(0007322) Ken Moreland (manager) 2007-04-16 11:54 |
Reset camera also resets the center of rotation. The undo does not restore the center of rotation. However, should it? Should the center of rotation go on the other undo stack? Should it be on any undo stack? |
(0007353) Ken Moreland (manager) 2007-04-17 13:46 |
The camera undo should also undo the center of rotation. |
(0007426) Mark Richardson (reporter) 2007-04-24 12:51 |
When the 3D view is made, the view undo button is enabled. I think this is due to the first reset camera. The view undo should be disabled when the view first comes up. |
(0007524) Utkarsh Ayachit (administrator) 2007-04-30 12:55 |
Reset camera undo undoes the changes to the center of rotation as well. Also so that this logic works correctly with linked views etc, when views are linked, their center of rotations are also linked. /cvsroot/ParaView3/ParaView3/Qt/Components/pqUndoStackBuilder.cxx,v <-- pqUndoStackBuilder.cxx new revision: 1.2; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Core/pqRenderViewModule.cxx,v <-- pqRenderViewModule.cxx new revision: 1.50; previous revision: 1.49 /cvsroot/ParaView3/ParaView3/Qt/Core/pqRenderViewModule.h,v <-- pqRenderViewModule.h new revision: 1.23; previous revision: 1.22 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPVGenericRenderWindowInteractor.cxx,v <-- vtkPVGenericRenderWindowInteractor.cxx new revision: 1.5; previous revision: 1.4 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPVGenericRenderWindowInteractor.h,v <-- vtkPVGenericRenderWindowInteractor.h new revision: 1.5; previous revision: 1.4 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMCameraLink.cxx,v <-- vtkSMCameraLink.cxx new revision: 1.9; previous revision: 1.8 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMInteractionUndoStackBuilder.cxx,v <-- vtkSMInteractionUndoStackBuilder.cxx new revision: 1.3; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/rendering.xml,v <-- rendering.xml new revision: 1.153; previous revision: 1.152 |
(0007525) Utkarsh Ayachit (administrator) 2007-04-30 13:01 |
Fixed bug pointed to by Mark's comment. /cvsroot/ParaView3/ParaView3/Qt/Core/pqRenderViewModule.cxx,v <-- pqRenderViewModule.cxx new revision: 1.51; previous revision: 1.50 |
(0007579) Ken Moreland (manager) 2007-05-07 14:52 |
This still needs to be fixed on the 3.0 branch. |
