0004819 | ParaView | (No Category) | public | 2007-04-09 14:23 | 2009-05-13 13:47 | ||||
Reporter | Berk Geveci | ||||||||
Summary | 0004819: Cleanup progress handling | ||||||||
Description | Progress handling could use a rework. It should be done all in vtkPVProgressHandler. It should keep track of individual algorithm report intervals with timers and should report when the interval exceeds a configurable threshold. | ||||||||
Relationships | |||||||||||
(0011206) Berk Geveci (administrator) 2008-04-09 12:00 |
We won't have time for this in 3.4. |
(0014091) Utkarsh Ayachit (administrator) 2008-11-12 09:34 |
Cleaning progress handling. Rewrote vtkPVProgressHandler to ensure that it works in parallel. In the new design, CleanPendingProgress blocks till all processes are done reporting the progress thus ensuring that we don't miss out on progress events since the root is running faster than the satellites. Also added a new vtkPVMPICommunicator which overrides Receive() to consume progress events as and when they appear. Hence if the root is blocking on some arbitrary receive eg. GatherInformation(), it will still get the progress events sent by the satellites and report them to the client. /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMViewProxy.cxx,v <-- Servers/ServerManager/vtkSMViewProxy.cxx new revision: 1.20; previous revision: 1.19 /cvsroot/ParaView3/ParaView3/Servers/Common/CMakeLists.txt,v <-- Servers/Common/CMakeLists.txt new revision: 1.84; previous revision: 1.83 /cvsroot/ParaView3/ParaView3/Servers/Common/vtkClientConnection.cxx,v <-- Servers/Common/vtkClientConnection.cxx new revision: 1.10; previous revision: 1.9 /cvsroot/ParaView3/ParaView3/Servers/Common/vtkMPISelfConnection.cxx,v <-- Servers/Common/vtkMPISelfConnection.cxx new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Servers/Common/vtkPVMPICommunicator.cxx,v <-- Servers/Common/vtkPVMPICommunicator.cxx initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/Common/vtkPVMPICommunicator.h,v <-- Servers/Common/vtkPVMPICommunicator.h initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/Common/vtkPVProgressHandler.cxx,v <-- Servers/Common/vtkPVProgressHandler.cxx new revision: 1.12; previous revision: 1.11 /cvsroot/ParaView3/ParaView3/Servers/Common/vtkPVProgressHandler.h,v <-- Servers/Common/vtkPVProgressHandler.h new revision: 1.3; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Servers/Common/vtkProcessModule.cxx,v <-- Servers/Common/vtkProcessModule.cxx new revision: 1.90; previous revision: 1.89 /cvsroot/ParaView3/ParaView3/Servers/Common/vtkProcessModule.h,v <-- Servers/Common/vtkProcessModule.h new revision: 1.68; previous revision: 1.67 /cvsroot/ParaView3/ParaView3/Servers/Common/vtkProcessModuleConnection.cxx,v <-- Servers/Common/vtkProcessModuleConnection.cxx new revision: 1.13; previous revision: 1.12 /cvsroot/ParaView3/ParaView3/Servers/Common/vtkProcessModuleConnection.h,v <-- Servers/Common/vtkProcessModuleConnection.h new revision: 1.10; previous revision: 1.9 /cvsroot/ParaView3/ParaView3/Servers/Common/vtkSelfConnection.cxx,v <-- Servers/Common/vtkSelfConnection.cxx new revision: 1.5; previous revision: 1.4 /cvsroot/ParaView3/ParaView3/Servers/Common/vtkServerConnection.cxx,v <-- Servers/Common/vtkServerConnection.cxx new revision: 1.16; previous revision: 1.15 |
(0014144) Alan Scott (manager) 2008-11-19 18:24 |
YES! This is orders of magnitude better than we had. Good job. Tested client/server, 6 servers, dave's medium cth data, and with can. |
2008-04-09 12:00 | Berk Geveci | Note Added: 0011206 | |
2008-04-09 12:00 | Berk Geveci | Category | => 3.6 |
2008-11-12 09:28 | Utkarsh Ayachit | Relationship added | related to 0003925 |
2008-11-12 09:28 | Utkarsh Ayachit | Relationship added | related to 0005463 |
2008-11-12 09:34 | Utkarsh Ayachit | Note Added: 0014091 | |
2008-11-12 09:34 | Utkarsh Ayachit | Status | tabled => @80@ |
2008-11-12 09:34 | Utkarsh Ayachit | Resolution | open => fixed |
2008-11-19 18:24 | Alan Scott | Note Added: 0014144 | |
2008-11-19 18:24 | Alan Scott | Status | @80@ => closed |
2009-05-13 13:47 | Utkarsh Ayachit | Target Version | => 3.6 |
