0004861 | ParaView | (No Category) | public | 2007-04-13 10:59 | 2007-05-10 10:36 | ||||
Reporter | David Karelitz | ||||||||
Summary | 0004861: Load State disables Compositing | ||||||||
Description | Running client/server If you open an exodus file, save state, delete the exodus reader, load the state file, compositing is now disabled until it's disbaled and re-enabled in the server settings panel | ||||||||
(0007340) Utkarsh Ayachit (administrator) 2007-04-17 10:00 |
Two properties were referring to the same iVar (CompositeThreshold==RemoteRenderThreshold). When state was loaded RemoteRenderThreshold would always override CompositeThreshold. Fixed by removing CompositeThreshold property. /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/rendering.xml,v <-- rendering.xml new revision: 1.151; previous revision: 1.150 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Testing/SMStates/BlowTest.pvsm,v <-- BlowTest.pvsm new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Testing/SMStates/ClipCut.pvsm,v <-- ClipCut.pvsm new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Qt/Components/pq3DViewPropertiesWidget.cxx,v <-- pq3DViewPropertiesWidget.cxx new revision: 1.18; previous revision: 1.17 /cvsroot/ParaView3/ParaView3/Qt/Core/pqRenderViewModule.cxx,v <-- pqRenderViewModule.cxx new revision: 1.48; previous revision: 1.47 |
