0004888 | ParaView | (No Category) | public | 2007-04-16 13:45 | 2007-05-10 10:39 | ||||
Summary | 0004888: Text sources do not work in client/server | ||||||||
Description | When I try to create a text source in client/server mode, I get the following errors, and no text is displayed: Warning: In C:\kmorel\src\ParaView3\VTK\Filtering\vtkDataObject.cxx, line 852 vtkTable (08821660): Attempted to ShallowCopy from null. ERROR: In C:\kmorel\src\ParaView3\VTK\Rendering\vtkFreeTypeUtilities.cxx, line 1793 vtkFreeTypeUtilities (0881A8C8): no text in input ERROR: In C:\kmorel\src\ParaView3\VTK\Rendering\vtkOpenGLTexture.cxx, line 106 vtkOpenGLTexture (08817778): No scalar values found for texture input! ERROR: In C:\kmorel\src\ParaView3\VTK\Rendering\vtkFreeTypeUtilities.cxx, line 1793 vtkFreeTypeUtilities (0881A8C8): no text in input ERROR: In C:\kmorel\src\ParaView3\VTK\Rendering\vtkOpenGLTexture.cxx, line 106 vtkOpenGLTexture (08817778): No scalar values found for texture input! The last error is repeated each time a render occurs. | ||||||||
(0007334) Utkarsh Ayachit (administrator) 2007-04-16 17:21 |
Two problems: 1. Collect filter was connected after update suppressor, which lead to collect filter no updating correctly and 2. The client connection was not set on the Collect filter because of which it could not deliver data to the client. Fixed both." /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMTextDisplayProxy.cxx,v <-- vtkSMTextDisplayProxy.cxx new revision: 1.4; previous revision: 1.3 |
