0004921 | ParaView | (No Category) | public | 2007-04-24 15:34 | 2007-05-01 10:50 | ||||
Reporter | David Gregory | ||||||||
Priority | low | Severity | major | Reproducibility | always | ||||
Summary | 0004921: SNL: Extract CTH Parts in 2.9.9 | ||||||||
Description | When using the extract CTH parts filter, initially setting the Volume fraction value (prior to the first "Accept) to a value other than 0.1 causes Paraview to crash. To Reproduce: Open spcth file and select at least one material. Filter -> Extract CTH Part Set Volume fraction value to any value other than 0.1 The exact same bug is present in 2.6.0 and 2.6.1 (see 0004521) Accept Workaround: Initially create the part with volume fraction of 0.1, then changed the volume fraction after the part is created. | ||||||||
(0007433) Ken Moreland (manager) 2007-04-24 17:17 |
I believe this has been fixed. I just tried it on the current CVS snapshot, and it works fine. |
