0004969 | ParaView | (No Category) | public | 2007-05-04 15:38 | 2007-05-15 13:53 | ||||
Reporter | Clinton Stimpson | ||||||||
Summary | 0004969: undo of Xdmf open has problems | ||||||||
Description | One can open a file, hit accept 2 times to get back to the state before opening the file. But with opening an Xdmf file, one can push the undo button *many* times and still not get back. If you push it enough, ParaView will crash. pqXDMFPanel appears to be very undo/redo un-friendly. And it pushes properties and pulls changed property values outside of the accept()/reset() functions. Doing that on a clone of the proxy would work without messing up undo/redo (see pqExodusPanel for example). The clone wouldn't be needed after the first accept. | ||||||||
(0007601) Clinton Stimpson (developer) 2007-05-09 12:06 |
/cvsroot/ParaView3/ParaView3/Qt/Components/pqXDMFPanel.cxx,v <-- pqXDMFPanel.cxx new revision: 1.14; previous revision: 1.13 /cvsroot/ParaView3/ParaView3/Qt/Components/pqXDMFPanel.h,v <-- pqXDMFPanel.h new revision: 1.8; previous revision: 1.7 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqXDMFPanel.ui,v <-- pqXDMFPanel.ui new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/utilities.xml,v <-- utilities.xml new revision: 1.110; previous revision: 1.109 /cvsroot/ParaView3/ParaView3/Utilities/Xdmf/vtk/vtkXdmfReader.cxx,v <-- vtkXdmfReader.cxx new revision: 1.75; previous revision: 1.74 Fixed several possible crashes. Fixed undo/redo to work just like it does with other sources/readers. |
(0007623) Clinton Stimpson (developer) 2007-05-10 16:34 |
/cvsroot/ParaView3/ParaView3/Qt/Components/pqXDMFPanel.cxx,v <-- pqXDMFPanel.cxx new revision: 1.13.2.1; previous revision: 1.13 /cvsroot/ParaView3/ParaView3/Qt/Components/pqXDMFPanel.h,v <-- pqXDMFPanel.h new revision: 1.7.8.1; previous revision: 1.7 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqXDMFPanel.ui,v <-- pqXDMFPanel.ui new revision: 1.4.8.1; previous revision: 1.4 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/utilities.xml,v <-- utilities.xml new revision: 1.109.2.1; previous revision: 1.109 /cvsroot/ParaView3/ParaView3/Utilities/Xdmf/vtk/vtkXdmfReader.cxx,v <-- vtkXdmfReader.cxx new revision: 1.74.10.1; previous revision: 1.74 |
