0005008 | ParaView | (No Category) | public | 2007-05-10 09:16 | 2007-05-17 15:38 | ||||
Summary | 0005008: Rescale to Data Range should force render | ||||||||
Description | In the display panel when you click "Rescale to Data Range" it appears to do nothing. Then when you interact with the view it is attached to, the data range gets updated. When you click this button, it should force a render of the view it is attached to so that effects are immediately seen. | ||||||||
(0007640) Utkarsh Ayachit (administrator) 2007-05-14 09:30 |
Clint already fixed this. (pqDisplayProxyEditor.cxx rev. 1.27). |
(0007642) Clinton Stimpson (developer) 2007-05-14 10:56 |
Didn't realize this was in the bug tracker :) I came across it when adding tests. /cvsroot/ParaView3/ParaView3/Qt/Components/pqDisplayProxyEditor.cxx,v <-- pqDisplayProxyEditor.cxx new revision: 1.24.2.3; previous revision: 1.24.2.2 |
