0005019 | ParaView | (No Category) | public | 2007-05-11 12:59 | 2011-01-13 17:00 | ||||
Reporter | David Karelitz | ||||||||
Summary | 0005019: ExodusReader->D3->CellToPoint Error with bad GlobalNodeId's | ||||||||
Description | If you open a split exodus dataset with bad globalNodeId's (duplicated among files), then Run D3, and finally apply CellToPoint, the result is a "sparse" dataset. Turning off the GlobalNodeId aray in the Exodus reader results in a valid D3 display, but CellToPoint is still messed up. Basically instead of seeing a nice box, you see a shredded box. | ||||||||
(0007716) Ken Moreland (manager) 2007-05-22 11:17 |
The issue was that vtkDistributedDataFilter was incorrectly withholding the flag to use global point ids from vtkMergeCells. Thus, vtkMergeCells was using its default tolerance for merging points, which was 0.001. Since the cell sizes were less than that, points were being incorrectly merged. I fixed this issue as well as another issue where D3 was sometimes using global ids when they were not available. /cvsroot/ParaView3/ParaView3/VTK/Parallel/vtkDistributedDataFilter.cxx,v <-- vtkDistributedDataFilter.cxx new revision: 1.44; previous revision: 1.43 I also added a regression test for data sets with small cells. /cvsroot/ParaView3/ParaViewData/Baseline/D3SmallCells.png,v <-- D3SmallCells.png initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Applications/Client/CMakeLists.txt,v <-- CMakeLists.txt new revision: 1.130; previous revision: 1.129 /cvsroot/ParaView3/ParaView3/Applications/Client/Testing/XML/D3SmallCells.xml,v <-- D3SmallCells.xml initial revision: 1.1 |
2011-01-13 17:00 | Source_changeset_attached | => VTK master a2bd8391 | |
2011-01-13 17:00 | Source_changeset_attached | => VTK master 020ef709 | |
