0005048 | ParaView | (No Category) | public | 2007-05-17 10:17 | 2007-06-26 10:41 | ||||
Priority | low | Severity | major | Reproducibility | always | ||||
Summary | 0005048: Recorded scrollbar movement does not play | ||||||||
Description | If you record a test where you move the vertical scrollbar in the Properties tab of the object inspector and then create an xml client test, you get an error about the object not being found while the test is run. | ||||||||
(0007689) Clinton Stimpson (developer) 2007-05-18 12:08 |
pqAbstractSliderEventTranslator.cxx new revision: 1.3; previous revision: 1.2 They aren't recorded anymore, so you won't get that error when playing back. |
(0007899) Clinton Stimpson (developer) 2007-06-15 18:43 |
I'll just mark this fixed. It hasn't been decided yet whether to implement recording/playback of scrollbars. For now, we don't need to and we're not going to. |
