0005053 | ParaView | (No Category) | public | 2007-05-17 15:08 | 2007-11-01 20:34 | ||||
Reporter | David Karelitz | ||||||||
Summary | 0005053: Changing display properties of a line graph (line visibility) is horrendously slow in parallel | ||||||||
Description | Changing the display properties of a line graph when running with large data in parallel is horrendously slow. It takes on the order of 30 seconds to hide a line. For most cases you need to hide time, globalnodeid, blockid, and pedigreelementid and set the Y array to time and not index for it to be a useful graph. This takes a few minutes. It should take a few seconds. | ||||||||
(0008424) Berk Geveci (administrator) 2007-08-13 14:34 |
Can you check if this is still the case? If yes, can you provide more information on the setup and data? |
(0009305) Mark Richardson (reporter) 2007-09-26 16:41 |
I improved the plot view update process to layout the chart only when needed. |
(0009614) Alan Scott (manager) 2007-11-01 20:34 |
I tested this client/server with can on 3.2, and it seemed fine. |
2007-08-13 14:34 | Berk Geveci | Note Added: 0008424 | |
2007-09-26 16:41 | Mark Richardson | Status | tabled => @80@ |
2007-09-26 16:41 | Mark Richardson | Resolution | open => fixed |
2007-09-26 16:41 | Mark Richardson | Note Added: 0009305 | |
2007-11-01 20:34 | Alan Scott | Status | @80@ => closed |
2007-11-01 20:34 | Alan Scott | Note Added: 0009614 | |
