0005102 | ParaView | (No Category) | public | 2007-05-29 18:11 | 2011-01-13 17:00 | ||||
Assigned To | Amy Squillacote | ||||||||
Summary | 0005102: Crash when negating function | ||||||||
Description | A crash occurs when you do the following: 1. Create a wavelet source with the default values. 2. Add a calculator filter with the following function: -sin(RTData) ParaView crashes when you hit accept. You can get around the problem by surrounding the sin function with parens. | ||||||||
(0008485) Amy Squillacote (reporter) 2007-08-16 12:48 |
I just checked in a fix for this. /cvsroot/ParaView3/ParaView3/VTK/Common/vtkFunctionParser.cxx,v <-- vtkFunctionParser.cxx new revision: 1.35; previous revision: 1.34 |
2007-08-13 14:36 | Berk Geveci | Assigned To | Berk Geveci => Amy Squillacote |
2007-08-16 12:48 | Amy Squillacote | Note Added: 0008485 | |
2007-08-16 12:49 | Amy Squillacote | Status | tabled => @80@ |
2007-08-16 12:49 | Amy Squillacote | Resolution | open => fixed |
2007-08-21 12:46 | Ken Moreland | Status | @80@ => closed |
2011-01-13 17:00 | Source_changeset_attached | => VTK master a2bd8391 | |
2011-01-13 17:00 | Source_changeset_attached | => VTK master 020ef709 | |
