0005242 | ParaView | (No Category) | public | 2007-06-26 15:49 | 2007-09-13 21:58 | ||||
Reporter | David Karelitz | ||||||||
Status | closed | Resolution | unable to reproduce | ||||||
Summary | 0005242: Array Calculator not tolerant of changing input arrays | ||||||||
Description | This happened while running in parallel, but it seems like it will happen if running serially as well If you 1. load a dataset 2. make a calculator that computes some function on point array data 3. Accept 4. turn off the point array you used in the calculator 5. Accept ParaView then crashes with errors about invalid array names. Process id: 0 >> ERROR: In /scratch2/dbkarel/ParaView3/ParaView3-Release/ParaView3/VTK/Graphics/vtkArrayCalculator.cxx, line 249 vtkArrayCalculator (0xc1cd1e0): Invalid array name: ACC_ | ||||||||
(0008427) Berk Geveci (administrator) 2007-08-13 14:44 |
It will still produce error but we will fix the crash. |
(0008914) Berk Geveci (administrator) 2007-09-10 17:39 |
I can reproduce the error but I cannot reproduce the crash. Since the error is expected, I am setting this to resolved. Tried: * built-in connection * 2 node server with compositing * 3 node server with local rendering Data is brick_wall_mp with D3 applied |
2007-08-13 14:44 | Berk Geveci | Note Added: 0008427 | |
2007-09-10 17:39 | Berk Geveci | Status | tabled => @80@ |
2007-09-10 17:39 | Berk Geveci | Resolution | open => unable to reproduce |
2007-09-10 17:39 | Berk Geveci | Note Added: 0008914 | |
2007-09-13 21:58 | Alan Scott | Status | @80@ => closed |
