0005247 | ParaView | (No Category) | public | 2007-06-27 13:05 | 2009-05-13 13:59 | ||||
Reporter | Clinton Stimpson | ||||||||
Status | closed | Resolution | unable to reproduce | ||||||
Summary | 0005247: too many renders when hitting accept | ||||||||
Description | We get at least a few calls to vtkRenderWindow::Render for the first time accept is pressed. Not yet sure why that happens. When changing any parameters afterwards, hitting accept leads to 2 calls to vtkRenderWindow::Render(). The second is caused by the display representation widget watching to update itself on a queued connection, and updating itself causes another render. | ||||||||
(0007954) Clinton Stimpson (developer) 2007-06-28 12:12 |
/cvsroot/ParaView3/ParaView3/Qt/Components/pqDisplayRepresentationWidget.cxx,v <-- pqDisplayRepresentationWidget.cxx new revision: 1.13; previous revision: 1.12 |
(0007955) Clinton Stimpson (developer) 2007-06-28 12:19 |
Still have 5 renders when pressing accept for the first time on a new source. We get 3 renders when hitting accept to create a second source. Creating a filter, before accept, with a 3d widget causes 2 renders instead of 1. |
(0011353) Utkarsh Ayachit (administrator) 2008-04-15 16:36 |
I put a print statement in vtkSMViewProxy::StillRender(). Here's what I observer: * Create sphere -- no render * Apply sphere -- 1 render * create clip -- 1 render (needed since we are not showing the 3D widget) * apply clip -- 1 render I used the toolbar to create the clip filter. If you use the menu, then it will repaint the QVTKWidget causing additional renders. |
(0011361) Alan Scott (manager) 2008-04-15 17:00 |
Internal to ParaView. Closed. |
2008-04-09 21:02 | Berk Geveci | Assigned To | Berk Geveci => Utkarsh Ayachit |
2008-04-09 21:02 | Berk Geveci | Priority | low => normal |
2008-04-09 21:02 | Berk Geveci | Category | => 3.4 |
2008-04-15 16:36 | Utkarsh Ayachit | Status | tabled => @80@ |
2008-04-15 16:36 | Utkarsh Ayachit | Resolution | open => unable to reproduce |
2008-04-15 16:36 | Utkarsh Ayachit | Note Added: 0011353 | |
2008-04-15 17:00 | Alan Scott | Status | @80@ => closed |
2008-04-15 17:00 | Alan Scott | Note Added: 0011361 | |
