0005299 | ParaView | (No Category) | public | 2007-07-06 10:23 | 2007-07-17 10:27 | ||||
Reporter | Amy Squillacote | ||||||||
Summary | 0005299: loading data into new view | ||||||||
Description | Run ParaView in client server mode with compositing turned on and the compositing threshold set to 0. Divide the initial render window into 2, but don't choose its type. With the new render window selected, choose Sphere from the Source menu and click Apply. The following error message will appear. ERROR: In ..\..\..\ParaView3\Servers\Common\vtkProcessModuleConnection.cxx, line 162 vtkServerConnection (07169DD8): Internal ParaView Error: Socket Communicator received wrong tag: 834343 At this point, the application freezes; you can't even click Clear or Close on the Output Messages dialog. | ||||||||
(0008005) Utkarsh Ayachit (administrator) 2007-07-06 15:08 |
The problem was that the StillRender was getting called within a StillRender call. This was because iren->Initialize() would trigger a render. Fixed that. /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMViewProxy.cxx,v <-- vtkSMViewProxy.cxx new revision: 1.16; previous revision: 1.15 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMViewProxy.h,v <-- vtkSMViewProxy.h new revision: 1.13; previous revision: 1.12 /cvsroot/ParaView3/ParaView3/Qt/Components/pqViewManager.cxx,v <-- pqViewManager.cxx new revision: 1.35; previous revision: 1.34 |
