0005339 | ParaView | (No Category) | public | 2007-07-13 12:46 | 2007-09-05 16:39 | ||||
Summary | 0005339: No scale on vol ren scalar opacity mapping | ||||||||
Description | For unstructured volume rendering, it is important to have a scale parameter for the opacity mapping that defines what a unit length with respect to the opacity value means with respect to the model. ParaView 2 had this parameter, but it is missing in ParaView 3. To see the need for the parameter, first create a wavelet source, convert it to an unstructured grid (filter it with Clean to Grid) and volume render it. The result will be an appropriately fuzzy image. Now run that through the transform filter to scale each dimension by 100. Volume render the result and it will look very opaque. This is because the opacity is now accumulating 100x as much as before the scaling. | ||||||||
(0008716) Utkarsh Ayachit (administrator) 2007-08-28 13:57 |
This has been fixed. |
(0008736) Ken Moreland (manager) 2007-08-29 12:59 |
How is this fixed? I don't see any change. |
(0008742) Utkarsh Ayachit (administrator) 2007-08-29 13:32 |
There's a Scalar Opacity Unit distance widget on the display tab. What was missing, I guess, is setting the default value based on the bounds, which is now added. /cvsroot/ParaView3/ParaView3/Qt/Core/pqPipelineRepresentation.cxx,v <-- pqPipelineRepresentation.cxx new revision: 1.11; previous revision: 1.10 |
(0008783) Ken Moreland (manager) 2007-08-30 15:11 |
One more small request. Could you move the Scalar Opacity Unit Distance dialog box to the Color Scale Editor dialog box? That is where it was in ParaView 2 and where I would expect it now. |
(0008787) Utkarsh Ayachit (administrator) 2007-08-31 10:04 |
Moved scalar opacity unit distance widget to color scale editor dialog. /cvsroot/ParaView3/ParaView3/Qt/Components/pqColorScaleEditor.cxx,v <-- pqColorScaleEditor.cxx new revision: 1.33; previous revision: 1.32 /cvsroot/ParaView3/ParaView3/Qt/Components/pqDisplayProxyEditor.cxx,v <-- pqDisplayProxyEditor.cxx new revision: 1.41; previous revision: 1.40 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqColorScaleDialog.ui,v <-- pqColorScaleDialog.ui new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqDisplayProxyEditor.ui,v <-- pqDisplayProxyEditor.ui new revision: 1.25; previous revision: 1.24 |
2007-08-23 10:50 | Berk Geveci | Assigned To | Berk Geveci => Utkarsh Ayachit |
2007-08-23 10:50 | Berk Geveci | Priority | normal => high |
2007-08-28 13:57 | Utkarsh Ayachit | Note Added: 0008716 | |
2007-08-28 13:57 | Utkarsh Ayachit | Status | tabled => @80@ |
2007-08-28 13:57 | Utkarsh Ayachit | Resolution | open => fixed |
2007-08-29 12:59 | Ken Moreland | Status | @80@ => @20@ |
2007-08-29 12:59 | Ken Moreland | Resolution | fixed => reopened |
2007-08-29 12:59 | Ken Moreland | Note Added: 0008736 | |
2007-08-29 13:32 | Utkarsh Ayachit | Status | @20@ => @80@ |
2007-08-29 13:32 | Utkarsh Ayachit | Resolution | reopened => fixed |
2007-08-29 13:32 | Utkarsh Ayachit | Note Added: 0008742 | |
2007-08-30 15:11 | Ken Moreland | Status | @80@ => @20@ |
2007-08-30 15:11 | Ken Moreland | Resolution | fixed => reopened |
2007-08-30 15:11 | Ken Moreland | Note Added: 0008783 | |
2007-08-31 10:04 | Utkarsh Ayachit | Status | @20@ => @80@ |
2007-08-31 10:04 | Utkarsh Ayachit | Resolution | reopened => fixed |
2007-08-31 10:04 | Utkarsh Ayachit | Note Added: 0008787 | |
2007-09-05 16:39 | Ken Moreland | Status | @80@ => closed |
