0005415 | ParaView | (No Category) | public | 2007-07-26 16:24 | 2009-05-13 13:59 | ||||
Summary | 0005415: Feature: Reverse selection | ||||||||
Description | I have had two groups ask for the ability to do a reverse selection. What I mean is to allow the user to open the Element Inspector, to enter a Cell Id in the element inspector window, and have the cell highlighted in the main window. Allowing the user to input the blockId would be wonderful also. If this is easy, I would call it a high priority. If not, medium. | ||||||||
(0008753) Berk Geveci (administrator) 2007-08-29 15:24 |
We started working on this. You can currently use the selection inspector to type ids (global and index) to select points and elements. In 3.4, we will have support for showing only these in the spreadsheet view. |
(0009310) Utkarsh Ayachit (administrator) 2007-09-27 11:28 |
Added ability to show only the selected elements in the spreadsheet view. There's a new check box on the display panel to show selected entires alone. /cvsroot/ParaView3/ParaView3/Qt/Components/pqSpreadSheetDisplayEditor.cxx,v <-- pqSpreadSheetDisplayEditor.cxx new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqSpreadSheetDisplayEditor.ui,v <-- pqSpreadSheetDisplayEditor.ui new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/Qt/Core/pqSpreadSheetViewModel.cxx,v <-- pqSpreadSheetViewModel.cxx new revision: 1.12; previous revision: 1.11 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMBlockDeliveryRepresentationProxy.cxx,v <-- vtkSMBlockDeliveryRepresentationProxy.cxx new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMBlockDeliveryRepresentationProxy.h,v <-- vtkSMBlockDeliveryRepresentationProxy.h new revision: 1.5; previous revision: 1.4 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMSpreadSheetRepresentationProxy.cxx,v <-- vtkSMSpreadSheetRepresentationProxy.cxx new revision: 1.2; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMSpreadSheetRepresentationProxy.h,v <-- vtkSMSpreadSheetRepresentationProxy.h new revision: 1.2; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/rendering.xml,v <-- rendering.xml new revision: 1.254; previous revision: 1.253 |
(0011358) Utkarsh Ayachit (administrator) 2008-04-15 16:52 |
We already support showing only the selected, cells or points in the spreadsheet view. |
(0011421) Alan Scott (manager) 2008-04-17 18:32 |
Wow, great! Tested client/server. |
2007-08-29 15:24 | Berk Geveci | Note Added: 0008753 | |
2007-08-29 15:24 | Berk Geveci | Assigned To | Berk Geveci => Utkarsh Ayachit |
2007-08-29 15:24 | Berk Geveci | Category | => 3.2 |
2007-08-29 15:25 | Berk Geveci | Category | 3.2 => 3.4 |
2007-09-27 11:28 | Utkarsh Ayachit | Note Added: 0009310 | |
2008-04-15 16:52 | Utkarsh Ayachit | Status | tabled => @80@ |
2008-04-15 16:52 | Utkarsh Ayachit | Resolution | open => fixed |
2008-04-15 16:52 | Utkarsh Ayachit | Note Added: 0011358 | |
2008-04-17 18:32 | Alan Scott | Status | @80@ => closed |
2008-04-17 18:32 | Alan Scott | Note Added: 0011421 | |
