0005419 | ParaView | (No Category) | public | 2007-07-27 10:39 | 2007-09-13 16:20 | ||||
Assigned To | Yumin Yuan | ||||||||
Summary | 0005419: Make center of rotation coordinates easier to set | ||||||||
Description | Right now, if you want to enter coordinates for the center of rotation, you have to go to Edit -> Settings -> Annotation, then click Use Custom Center and finally enter the coordinates. That is a long way away. Let's move this a bit closer. Either have a toolbar button that pops up entry fields for setting it (like PV 2) or add it to the Adjust Camera settings that are available with one click. | ||||||||
(0008755) Berk Geveci (administrator) 2007-08-29 15:28 |
Let's move this to the "Adjust Camera" panel. |
(0008892) Yumin Yuan (developer) 2007-09-07 15:49 |
Done, moved to Adjust Camera Dialog cvs commit Qt/Components/pqCameraDialog.cxx,v <-- pqCameraDialog.cxx new revision: 1.2; previous revision: 1.1 Qt/Components/pqCameraDialog.h,v <-- pqCameraDialog.h new revision: 1.2; previous revision: 1.1 Qt/Components/pqRenderViewOptions.cxx,v <-- pqRenderViewOptions.cxx new revision: 1.2; previous revision: 1.1 Qt/Components/Resources/UI/pqCameraDialog.ui,v <-- pqCameraDialog.ui new revision: 1.2; previous revision: 1.1 Qt/Components/Resources/UI/pqRenderViewOptions.ui,v <-- pqRenderViewOptions.ui new revision: 1.2; previous revision: 1.1 |
2007-08-16 14:34 | Berk Geveci | Assigned To | Berk Geveci => Dave DeMarle |
2007-08-29 15:28 | Berk Geveci | Note Added: 0008755 | |
2007-08-29 15:28 | Berk Geveci | Assigned To | Dave DeMarle => Yumin Yuan |
2007-08-29 15:28 | Berk Geveci | Category | => 3.2 |
2007-08-29 15:29 | Berk Geveci | Priority | normal => high |
2007-09-07 15:49 | Yumin Yuan | Status | tabled => @80@ |
2007-09-07 15:49 | Yumin Yuan | Resolution | open => fixed |
2007-09-07 15:49 | Yumin Yuan | Note Added: 0008892 | |
2007-09-13 16:20 | Alan Scott | Status | @80@ => closed |
